I'm sure there are many of you out there who have conquered this task. I am at the beginning and am just looking for suggestions of where to start or methods that have worked for you. Thanks.
OK, a little bit on troubleshooting basics....
ALL electrical faults are not "Shorts", that is reserved for a malfunction in which there is a current path to ground that bypasses normal circuitry or takes a "Short" path to ground, usually popping a breaker, fuse, fuse link or burning something. That said, if you do have a Short somewhere and it has blown the fuse associated with that circuit, the lightbulb on the battery bubba thing is useless, the fuse has already told you where to start looking.
So, what is not working? Blown fuse? what have you checked? Do you have a chematic? can you read it? (not making fun, some can, some can't)
Be glad to help, but need a bit of info
best tool I have found is one of those little bitty testlight/screwdriver looking things with a sharp point. You can at least find out where you getting power to,or not. and ...their cheap.
