half shaft removal issues
Old Dec 26, 2006 | 05:34 PM
scottw's Avatar
scottw
Default half shaft removal issues
I'm in the process of taking off my trailing arms so they can be rebuit. I am having serious issues with the half shaft bolts. One bolt is pretty stripped by the brake caliper. I have some kroil on the way to try and get some of the rust broken up and hopefully I can get a grip and get it out. If that does not work I am thinking of possibly taking the bolts by the diff out and once I get the TA out, I can get a better angle on the stripped bolt.
Any thoughts?
Also, if I decided to have this done at a shop, how much would you think it would cost for taking the TAs out, rebuilding and replacing the strut rods?
I'm about fed up with this project but I don't think paying someone else is going to be in the budget.
Old Dec 26, 2006 | 08:39 PM
CorvetteTechInc's Avatar
CorvetteTechInc
Heat, heat and more heat.
Old Dec 26, 2006 | 08:48 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Any thoughts?
Get a six sided box wrench.
Old Dec 27, 2006 | 12:40 AM
gkz's Avatar
gkz
I visited a local machine shop the other day down in Raleigh; they charge $8per bolt removal. If they are going to do the TAs, perhaps they'll give you a break. I just removed my half shafts last week. One of the TA side bolts for the half shaft was going south; after soaking w/Liquid Wrench for a day, Hammerhead Fred's idea worked.
Old Dec 27, 2006 | 09:25 AM
TimAT's Avatar
TimAT
Before the Kroil arrives, run by the local Wal-Mart or hardware store and get a little bottle of Hoppe's #9 gun solvent. It'll knock the rust loose too..
Old Dec 27, 2006 | 09:57 AM
scottw's Avatar
scottw
I've been soaking it with PB Blaster for the better part of two weeks. I'll get a six sided wrench and see if I can get her to break loose.
Any thoughts on a total price to have the TAs replaced by a shop?
Old Dec 27, 2006 | 04:49 PM
C3 4ME's Avatar
C3 4ME
If you have the entire job done by a shop it's not going to be cheap. I spent over $500 earlier this year to have a TA bushing replaced and a 4 wheel alignment. I didn't feel comfortable enough to pull the TA myself and send it out. I learn more every day on this forum and would probably give it a shot myself next time.
To half shaft removal issues
