Exhaust System Bad.
Old Dec 27, 2006 | 05:23 AM
Burnt71's Avatar
Burnt71
Default Exhaust System Bad.
My exhaust system on my 1980 is shot. Catalytic converter gone , bolts rusted off at the manifold & holes in pipes. should I try to return everything to original? Where is the best place to purchase parts ? I'm thinking of redoing the entire system. Any advice ?
Old Dec 27, 2006 | 08:28 AM
Crab's Avatar
Crab
I went with true duals on my 80 without the cat. You'll see a big improvement in performance. I had a local muffler shop fit a dual system on mine using stainless steel Magnaflow mufflers
You just want to make sure that you can get your car inspected after its done. I know that Pa. does'nt do an emissions test on cars driven under 5k miles, which is'nt a problem for me. If you want a bolt on system I think mid america has a system from manifold pipes to the mufflers aviliable in aluminized or stainless, it is called an off road exhaust, because there is no cat. You can get a bolt on Magnaflow from Corvette Central with the proper bends needed. If you go this route I don't know how it all would fit together,that is why I had a local shop do mine. Good Luck.
Old Dec 27, 2006 | 11:57 AM
Durango_Boy's Avatar
Durango_Boy
Hey man...this is a perfect chance to get a set of headers, and have a custom S/S true dual exhaust system. Buy the headers from a vendor, and have a local muffler shop to the exhaust. The whole thing at once can be pricey but it's worth it once you hear it, and the S/S pipes will last for a VERY long time.
Old Dec 27, 2006 | 03:17 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: I went with the stock set up on my '80, although I chose a high flow catcon. Got it all from ZIP Products. The manager at my favorite muffler shop said they could not remove any emissions control devices unless they were being replaced with the same thing. He could not create duals for me.
Old Dec 27, 2006 | 03:39 PM
Pusher's Avatar
Pusher
I'm a little biased, I owned a exhaust shop. I would try and find a quality shop and see if they are willing to do what you want, if not be sure and do some research on "ordered" exhaust as most of the time they do not just bolt up. Spend more now or spend more later. Good luck...
80CV, nice car and good choice with the MF's...
Old Dec 27, 2006 | 05:14 PM
Durango_Boy
You will have to shop around for a good shop willing to do the work...but they exist, because you are not the only car enthusiast with a smog car that wants a true dual system.
Old Dec 27, 2006 | 05:34 PM
Jims79's Avatar
Jims79
you should do the entire system, but the aluminize pipes and mufflers on mine look the same today as they did four years ago when I put them on. The only rust is on my coated headers. I did not buy the good ones and wish I had. So I think unless you have a boat load of cash you don't need SS pipes & mufflers. Also the SS system sounds a little tinny to me. my .02
Old Dec 27, 2006 | 07:36 PM
Durango_Boy
Great points. S/S or aluminized...either way...you want to pick a material that will last. Nothing looks worse than a rusty exhaust system showing from behind your car. Drive behind your Vette sometime...and you'll see more than you thought you could. That's what everyone else sees...and I use that to help design things with a special look in mind.
Old Dec 27, 2006 | 09:58 PM
kdf1986's Avatar
kdf1986
I would start with the emission and smog laws in your state. Let that dictate where you start from. From what I remember you cannot remove federal mandated emission control equipment from your car. I am not saying that it cant be done, but check with the regulations.
If there are ways around this, such as age of the car, collectors status, or minimum mileage amounts, then you can choose to go custom.
The difference between the price of a stock setup, to that of a performance setup may not really be that much. If you just look at the cost of a performance setup, you may think its too much. But since you have to replace the parts anyway, dont forget that you are really looking at the delta between replacement parts, and upgrading.
kdf
Old Dec 27, 2006 | 10:42 PM
gyopp's Avatar
gyopp
I have heard several here complain about the fit of these manufactured exhaust systems. I used Mid America stainless duals and they fit great.
Old Dec 27, 2006 | 11:14 PM
MN80Vette's Avatar
MN80Vette
Put "new" in from the heads back with full length headers and dual pipes and dual cats if you need them. I am SO glad I did.
I've posted details of my cross member mods on my '80 for dual pipes. Let me know if you want to know more.
'80's rock - light and no computers!
Old Dec 27, 2006 | 11:56 PM
Durango_Boy
Post pics bud. I think that visual would help him a lot. Gyopp - You too...pics of your exhaust kit?
Old Dec 28, 2006 | 01:32 AM
Burnt71's Avatar
Burnt71
Yes , I need to know more. sounds like this would still pass inspection. What did you do about the AIR pump ?
Old Dec 28, 2006 | 08:54 AM
MN80Vette's Avatar
MN80Vette
Here's the link to the thread where I posted pics and a step-by-step of what I did:
http://forums.corvetteforum.com/show....php?t=1580452
As I said, we don't have emissions tests in Minnesota anymore, so I did not install cats. In that thread, rihwoods said he passed California emissions for years with a dual cat system until they looked under the car and saw he didn't have a factory configuration. As kdf1986 says, check your PA emissions laws to see if you can change from single cat to dual cats.
What did I do about the AIR pump? Uh, well, you see, I forgot to look at my original engine to see how the AIR system was installed and I just couldn't figure out (if you know what I mean) how to install it on my GM crate engine. I think it's in a box somewhere in my garage attic.
I know taking emissions stuff off hurts resale, but I have no plans of selling my car as long as I can drive it. I'll worry about that when the time comes.
Old Dec 28, 2006 | 09:08 AM
Badazjeep's Avatar
Badazjeep
When I put my new crate motor in I went ahead and did the entire exhaust...ceramic coated headers from JEGS, true duals from a local exhaust shop, and flowmaster 40's. I opted to have a local ehaust place do the work so I knew there would be no fitment issues. Sounds great! No complaints!
Old Dec 28, 2006 | 09:10 AM
Jims79's Avatar
Jims79
Wow great job, post pic's of the rest of the system & mufflers used.
I don't think an improvement like that will hurt your resale but increase it.
Old Dec 28, 2006 | 10:33 AM
Durango_Boy
Magna Flows sound VERY good on my Durango. I started with Flow Masters, but didn't like the sound, so I switched. Not only do I like the sound better, it almost feels like it's breathing easier.
To Exhaust System Bad.
