Welding question
Old Dec 27, 2006 | 10:19 PM
JustForFun's Avatar
JustForFun
Default Welding question
Is a FLUX core wire weld, as strong/good as a mig wire weld of same material/size?
Old Dec 27, 2006 | 10:46 PM
SIXFOOTER's Avatar
SIXFOOTER
Flux will require more cleaning since it pops and spatters more, The gas shield is a cleaner weld. Thats about the extent of my wire welding knowledge at this point
Old Dec 27, 2006 | 11:10 PM
MN80Vette's Avatar
MN80Vette
Yes, but as others said, flux wire is dirty - lotsa spatters. Be SURE to gel your nozzle and groung clamp.
Old Dec 28, 2006 | 01:52 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Flux core diggs into the material a bit better, so you get better penetration. If you are using a 110v machine, it's what you need for thicker material.
Old Dec 28, 2006 | 06:13 PM
shafrs3's Avatar
shafrs3
It's also better at cleaning away contaminants. If your in a situation where you can't clean the surface properly, flux core is a good choice.
Old Dec 28, 2006 | 10:23 PM
SIXFOOTER's Avatar
SIXFOOTER
Makin a note....
Old Dec 29, 2006 | 01:53 AM
Burnt71's Avatar
Burnt71
I use it to avoid the tank.
To Welding question
