Painting Grill on my 81'
I would like to freshing up the looks of the grills and get rid of the grayish color. Has anyone ever painted them and if so what type of paint?
I would use SEMS brand vinyl / plastic color. Get the satin black and it'll have a little shine to it.
Just do it when the air / surface temp is at least 70 degrees or it'll haze on you. I had the best results during spring and summer.
I don't know how it will work for you, but there is a product call back to black that works well on some things. I was going to use it on my 80's front grill, but ran out of time (my car is 20 miles from where I live). It worked well on other black plastic parts.
This stuff works real good,better than armorall and I use it all the time on all my dark trim.You have to reapply quite offen.I might have a pair of NOS grills in my stock room I'll let got for say $25.00 for the pair.
Great thread and perfect timing. I just cleaned my grills up the other day and noticed the black needed a touch-up. I'll wait until this Spring, when it thaws out here in Maryland, and give the vinyl spray a shot. Thanks
I've used a spray on plastic paint from Orchard supply,you need to use the plastic primer first. Worked great on some outdoor projects, never used on car parts, but plastic is plastic...
I ended up trying Krylon Fusion satin on them. Turned ou pretty good. I also cleaned up the lens and repainted the black part on them as well.
I use WD40 on the Black plastic parts on my 80 and it brings the black back to life. An old trick I learned from a friend engineer at Chrisler corp. They use these tricks when they have open house and they make their display cars look great. Another trick he showed me and in a pinch for time have used myself quite often is to spray furniture polish on a terrycloth rag and wipe your car down for a shine that you wont believe. It also seems to keep the dust off as well.
Sprayed the ones on my '81 with stock, off the self, satin black paint in a rattle can (acrylic???). I thoroughly cleaned the grilles with detergent & then used wire wool to get rid of any flaking stuff & provide a key, then sprayed a few coats of paint, without a plastic primer. Came out surprisingly well & still looks good 4 years on. I wish I could say the same about the parts of the car that I had professionally painted
If you can get it, Sperex Polyurethane paint (satin black) has been excellent for tarting up the old black parts.
