High Beam Switch-Where is it??
Old Dec 28, 2006 | 08:43 PM
tedpav's Avatar
tedpav
Default High Beam Switch-Where is it??
Hi
i have a 77 vette and cant turn on the high beams on cause i cant find the switch!
i have looked at the floor foot area and theres nothing there, nor do any of the steering levers switch them.
where should i find it?
thanks
Old Dec 28, 2006 | 09:14 PM
rihwoods's Avatar
rihwoods
Originally Posted by tedpav
Hi
thanks
Your one stalk switch has turn signal and high beam switches...just pull straight back for high beam..
Rich
Old Dec 28, 2006 | 09:19 PM
82MDVette's Avatar
82MDVette
Left hand side of the steering column
Old Dec 28, 2006 | 09:28 PM
Durango_Boy's Avatar
Durango_Boy
The switch may be broken. If you have checked, pulled it towards you, and heard no click or see no change in lights...then the switch is bad. That means you can either drive around with low beams only, or take your steering column apart and replace the switch. If you have a tele/tilt wheel you're in for a real adventure.
Old Dec 28, 2006 | 09:33 PM
HoosierHoopsFan's Avatar
HoosierHoopsFan
Who drives their vette at night anyways? I mean, nobody can see my paint job that way!
Old Dec 28, 2006 | 09:34 PM
Durango_Boy
The deer can...heh heh.
SpeedE55's Avatar
SpeedE55
From: Where everyone's grandparents come to die, FL
True dat!!!
Old Dec 28, 2006 | 09:39 PM
tedpav's Avatar
tedpav
thanks guys.
Unfortunately i cant hear a click and it is a tele/tilt wheel!
Any hints or guides on how to go about it
I need these to work to get the car registered
thanks
Old Dec 28, 2006 | 09:41 PM
Durango_Boy
thanks guys.
thanks
Are you adept at working on your own Vette, and good at taking things apart that have a lot of specific parts that go in in a specific way? If not, or if you get things mixed up, or spend a lot of time in between steps...I suggest having a shop do it for you. It will cost more...but if you get into it, and lose your way you'll have to pay a shop to put her back together. I did it, did it well, and I almost wish I had taken it to a shop.
Old Dec 28, 2006 | 10:02 PM
tedpav's Avatar
tedpav
I am quite ok with these small components and have a a good mech background.
The problem of taking it to a shop is that i would struggle to find one in Oz which has experience in these.
I would firstly need to purchase the item, which i would do from corvette central. Their part no. is 593106. Is this all i'd require?
Should i pull it apart first to see whether it is fixable, or is it a foregone conclusion?
Old Dec 28, 2006 | 10:18 PM
Jim Shea's Avatar
Jim Shea
This is a writeup on the column mounted dimmer switch.
http://jimshea.corvettefaq.com/wp-co...radj28de06.doc
This is a trouble shooting page from one of my service manuals.
Hope that this helps,
Jim
Old Dec 28, 2006 | 11:04 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
If you do take the column apart make sure to order from corvette central one of these
HORN CONTACT CARRIER RETAINER; 563022
99% of the time its either broken or it will break when you try to remove it.
The part no you quoted is for the turnsignal switch not the dimmer.
I had the same problem as you and it turned out it was the accuvator cam was not making contact with the rod on the column.
You might want to check that before you order a new switch.
Old Dec 28, 2006 | 11:08 PM
Durango_Boy
In a '77 they are the same thing. The turn signal stalk IS the brights switch as well, and the head light switch is the gauge light dimmer.
Old Dec 28, 2006 | 11:44 PM
Mikes*Corvettes
Durango Boy
I think we have an Anglo-American language breakdown here.
What we call the dimmer switch i think you call the brights switch.
by meaning dimmer switch i meant this
http://www.zip-products.com/Corvette...B6684A255C6C11
The part no Tedpav quoted from corvettecentral ;593106 is the turn signal switch which is not what he needs
Old Dec 28, 2006 | 11:47 PM
tedpav's Avatar
tedpav
Thanks Dell Boy, i will order one of those also.
Thanks Jim Shea for your reply, i will use as a guide on dissassembly
I'm a little confused here, my 77 has the gauge dimmer on the on the pull **** for the lights, you rotate that to either turn the interior lights on, or dimmer gauges.
On my turn signal lever there are also the controls for the washer and wiper.
Is there different mechanism i need to order after i check whats wrong?
Old Dec 29, 2006 | 12:05 AM
Mikes*Corvettes
Tedpav read this post by Kortensi as he rebuilds a 77 column with pics
http://forums.corvetteforum.com/show...107000&page=19
its a lot easier to understand with pics
Old Dec 29, 2006 | 12:29 AM
tedpav's Avatar
tedpav
thanks Dell Boy.
The rod actuation to the dimmer switch is moving when i pull on the indicator handle, but i dont get any clicking or lights on high beam.
where is this clicking noise to come from?
And if this is the case and i only need to replace the dimmer switch at the bottom side of the steering column, then do i still need to pull the guts out of the steering column to change that. (looks messy in there!)
What the best way to replace it?
thanks
To High Beam Switch-Where is it??
Old Dec 29, 2006 | 12:56 AM
Mikes*Corvettes
First of all disconnect the battery,
then If i was you before i striped anything,i would remove the little dash panel just under the steering wheel.
With this removed if you get right under you should be able to see the dimmer/brights switch its the one with a rod running up the column towards the steering wheel.
There should be a small dimple where the rod fits into it.Use a screwdriver and press on the dimple you should hear a click,if it clicks chances are the switch is okay and the problem is the rod has come away from the cam further up,
(you can if you like at this stage carefully reconnect the battery and switch on your headlights press down on the dimple and hopefully your main beams should come on)
if they do then im affraid you will need to strip the top of the column,its not as bad as people make it out to be
(if i can do it being all fingers and thumbs,then im sure you can do it)
Old Dec 29, 2006 | 01:13 AM
noonie's Avatar
noonie
Hi
thanks
If you want a fast easy cheap way, you can just put a regular foot operated dimmer switch on the floor, just as in the 1976 and earlier models. You can buy the switch and pigtail at any parts store. The same switch fit 99% of the GM line.
If you don't want to drill holes in the floorboards you can just glue the switch to the floor with silicone or whatever and install it in such a way as it is easily reversable, should you repair the column lever switch.
My 77 was done this way before I got it and has been problem free.
Old Dec 29, 2006 | 03:40 AM
tedpav's Avatar
tedpav
All Done!
After painfully getting to the dimmer switch, i discovered all it needed was to be adjusted as per Jim Shea's trouble shooting guide.
Thanks to all those who helped with their information and knowledge, it was most valuable and i couldnt have fixed it without your replies.
This is a great forum and a must for vette owners.
