Long term storage advice needed
I'm deploying to Afgahnistan for the next year, so its not just the winter, and it won't be looked upon until I return for some R&R some 6 months later(if I can get to the area).
I also looked online, but I wasn't feeling confident on the info I saw. I mean, a special car requires special treatment right? I know some of the basics, such as, using sta-bil and disconnecting the battery.
The info I'm looking for is will the new tires (Goodyear Eagle GT II) develop flatspots? They lose very little air now, and I've been told that newer tires deter flatspots.
Now, if these people are incorrect and I need to put it up on jackstands where are the points on the rear?
Thats all I have for now, that I can think of. Thanks for answering these noob questions in advance!
Good luck. Stay safe.
The one thing I would do is to put in a battery disconnect switch. Older vettes tend to drain the battery easily
If you are going to put the car up on jackstands make sure you remove the wheels, seal the rotors with plastic, and don't let the suspension hang freely. Its also a good idea to support the front end as the nose has a tendency to sag if not supported.
Personally I would leave it on the ground.
Here is a typical storage procedure:
- change oil
- fill tank and add fuel stabilizer
- disconnect battery
- roll up the windows to keep the critters out
- lay out mouse deterrents (traps,mothballs,irish spring soap etc.)
- if you can, cover the car with car cover or soft blanket
I actually go so far as to cover the carb and tailpipes with plastic as a condensation barrier, but that's a personal thing and not scientifically proven. Lots of people don't and have no problems.
Be safe and enjoy your vette when you return. My thoughts will be with you and all serving over there.
No need for jack stands. Put in Stabil, fill the tank, put on a Battery Tender. No need to remove or disconnect the bat & do not start the car, not necessary.
Good Luck in Afgahistan
Fred
Once again thanks for the support and advice!
