Suction pump ??
Old Dec 30, 2006 | 07:17 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Suction pump ??
I've tried 2 of the "drill motor" liquid pumps to empty the rear end fluid from my 72. The stuff is just too thick. Some years back I used to have a big suction style plunger that worked like a reverse grease gun. I may go look for one of those....I haven't seen one lately.
Any suggestions?
Old Dec 30, 2006 | 07:21 PM
Twin_Turbo's Avatar
Twin_Turbo
do you have an air compressor? if so, hook a T up to the line, and run the "side" of the T to a big line that you insert into the fill hole, then hook the straioght shot through the T up to a big air gun (or even better an undercoating or sandblasting gun) and aim into a large jerry can and let 'er rip... instant "ported vacuum" suction device.
Old Dec 30, 2006 | 08:56 PM
Duke94's Avatar
Duke94
Any suggestions?
Most auto parts stores have them.
Old Dec 30, 2006 | 09:55 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I just used a clear nylon siphon hose to do one of mine. I think 3/8" line. About 5' of it. Clear so you can see the oil before you get a mouth full. Got it flowing and walked away for a couple of hours with the hose end hanging into a pan. Pretty much got all that was gonna be got.
Old Dec 30, 2006 | 09:56 PM
SmokinBBC's Avatar
SmokinBBC
Might want to drive it to heat the fluid up. Be carefull though it is hot back there with the exhaust.
To Suction pump ??
