Generic Front End Vibration Question
Old Jan 1, 2007 | 04:37 PM
ksbunting's Avatar
ksbunting
Default Generic Front End Vibration Question
I get a vibration between 60 and 80 mph that I can feel in the steering wheel.
Other than removing and replacng rotors, wheels, tires, front end components, etc. is there a "scientific" way to determine if the vibaration is as result of tires being out of balance or if it could be brake rotors?
Thank you,
Kurt
Old Jan 1, 2007 | 07:29 PM
72LS1Vette's Avatar
72LS1Vette
In my experience, vibration at those speeds is usually tire related. You could have the balance checked at a good tire store. Look for any bulges in the sidewalls that might indicate a tread separation also. If the tires are OK it would be worth finding a shop that can balance the wheels on the car so that you know the entire rotating assembly is balanced.
Rick B.
Old Jan 1, 2007 | 07:32 PM
ksbunting's Avatar
ksbunting
Rick B,
Thank you for the reply.
One more question: If one tire had slight wear on the outer edge due to alignment, (or hard cornering) could that cause such a vibration?
Why is the vibration not there at ALL speeds? Just curious.
Thanks again,
Kurt
Old Jan 1, 2007 | 10:22 PM
SIXFOOTER's Avatar
SIXFOOTER
If the tire has any kind of uneven wear it could cause the vibration.
Old Jan 1, 2007 | 10:29 PM
Vette Dent's Avatar
Vette Dent
Get the wheels balanced. That is probably the problem and it's not an expensive repair.
Old Jan 1, 2007 | 11:14 PM
Mark PittPayne's Avatar
Mark PittPayne
These types of vibrations are almost always the result of unbalanced wheels or used up tires.
Old Jan 1, 2007 | 11:41 PM
Tall Boy's Avatar
Tall Boy
Might be a bearing? Might check the lug-nuts? just ideas
Old Jan 1, 2007 | 11:47 PM
m and t's77's Avatar
m and t's77
The quickest way to isolate the problem is swapping the front tires to the rear and if you feel the vibration in the seat of your pants you know its tire related.Most times if you feel a vibration in the steering wheel its the front,if you feel it in your seat its in the rear.
Old Jan 2, 2007 | 12:23 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Take it to a shop with a Hunter GSP9700.
http://www.gsp9700.com/pub/technical/4127T/4127t.cfm
Old Jan 2, 2007 | 12:38 PM
682XLR8's Avatar
682XLR8
Exactly what I did to narrow down a vibration problem, found it was an out of balance tire
Old Jan 2, 2007 | 12:48 PM
rihwoods's Avatar
rihwoods
Make sure they don't "counter balance" a wheel..a tech once got lazy,and did that on mine..caused vibration....
Rich
Old Jan 2, 2007 | 02:36 PM
72LS1Vette's Avatar
72LS1Vette
Originally Posted by ksbunting
Rick B,
Thanks again,
Kurt
That wear could cause a vibration. The tire was balanced when new and the missing ounces of material could change the balance.
As to why the vibration occurs at higher speeds, I'm just speculating but I bet it's due to the mass of the tire hitting a resonant frequency at a certain speed. Sort of like a string on a guitar that starts vibrating in response to a sound that corresponds to its tuned note.
I have had other strange tire defects that you might want to look for also. If you take the wheel off and roll the tire slowly while looking across the tread down toward the ground you might see a deformed area in the tread cross-section. I had a noticeable divet in a tread cross-section once that caused a shimmy at walking speeds but went away at higher speeds. The tire store said it was caused by hitting a pothole or something like it that deformed the steel belt.
BTW, I have had good luck with alignments at NTB in Avon. They have the Hunter alignment machine. I did a search and there is a NTB in Natick.
Rick B.
To Generic Front End Vibration Question
