Composite Spring Shield, where do I get one?
Old Jan 4, 2007 | 09:29 PM
psw5940's Avatar
psw5940
Default Composite Spring Shield, where do I get one?
My 75 has a Composite rear spring. I've noticed in some photos here on the Forum, some people have what appears to be a stainless steel or aluminium piece attached to the bottom of the spring, at the center, below the Differential. I understand, this is to protect the spring from exhaust heat. Can you buy these?
How hard is it to put on?
Old Jan 4, 2007 | 09:53 PM
rosslato's Avatar
rosslato
if u have a Vette Brakes monospring just call VB's or email them to get their shield and if it's a TRW spring contact Muskegon Brake on getting a shield. you should be able to put one on by just removing the spring retainer plate or just to be safe remove the end bolts of the spring 1st.
Old Jan 4, 2007 | 09:58 PM
Crunch-o-Matic's Avatar
Crunch-o-Matic
however, the vette spring should have come with a heat shield in the first place.
Old Jan 4, 2007 | 10:14 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That thing was a stock part.
Old Jan 5, 2007 | 01:11 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Corvettemack(good seller) has one on ebay. $15 buy it now. item no. 120071812235
on my white 79
Old Jan 5, 2007 | 02:15 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
i had a compsite heavy duty rear spring in my other 68 big block automatic
HATED IT !!! WENT BACK TO STOCK !!!
Old Jan 5, 2007 | 08:30 AM
MN80Vette's Avatar
MN80Vette
The one that came with my VBP spring isn't long enough to protect my spring from my new dual exhaust, so I am going to make a new one. There are several places online that will cut stainless sheet of any thickness to any size. I am going to up the thickness of the shield while I'm at it. The original was a little too flimsy for me.
Old Jan 5, 2007 | 08:57 AM
1970-Bronze's Avatar
1970-Bronze
I didn't get a sheild with my dual mount set up.....
Old Jan 5, 2007 | 09:02 AM
rihwoods's Avatar
rihwoods
Make one...16 ga sheetmetal....
Old Jan 5, 2007 | 09:06 AM
72 LT1's Avatar
72 LT1
I didnt get a heat shield w/ my SS suspension kit either! I read a thread saying 3 inch min.clearance between glass spring and exhaust. Wish it came w/kit, looks like you have to take spring BACK out to instal a shield.
Old Jan 5, 2007 | 09:12 AM
1970-Bronze
Naw - I think you could make on without having to remove the spring.
Old Jan 5, 2007 | 09:20 AM
psw5940's Avatar
psw5940
Thanks for the replys. My car came with the spring but no shield.
Old Jan 6, 2007 | 09:01 AM
MN80Vette's Avatar
MN80Vette
Originally Posted by 72 LT1
Looks like you have to take spring BACK out to instal a shield.
No, you don't need to remove the spring to add a heat shield. You just need to remove the 4 bolts (3 bolts for '80-'82) to take off the spring mounting plate, hold the heat shield up on the spring, and re-install the mounting plate. I have mine off to add a traction bar I made.
Old Jan 6, 2007 | 09:30 AM
Hogwild's Avatar
Hogwild
Originally Posted by richwoods
Make one...16 ga sheet metal....
install side pipes then the spring will have no heat issues .
your legs will for a short period of time
To Composite Spring Shield, where do I get one?
