Rust Busters
Old Jan 7, 2007 | 10:17 PM
rajsid's Avatar
rajsid
Default Rust Busters
Ever since I purchased 'Rusty', my 78 t-top, I had been searching for reasonable rust control options.
Rusty had been sitting non-op for over two years in a coastal town when I found him.
After discarding expensive options like sandblasting+powder coating the frame, I have decided to pursue one of the below mentioned cheaper options.
It would be great if you folks could add your opinion along.
POR-15/POR-20
Advantages: Said to be the best solution against rust.
Disadvantages: Extremely toxic, Needs high heat curing (300 degree f)
Rust Bullet
Advantages: no prep needed, easy to use
Disadvantages: Not as durable as POR-15, Not any less toxic than POR-15
Rust Doctor
Advantages: Water Based !!!
Disadvantages: ??
Zero Rust
Advantages: Are there any ??
Disadvantages: Claims to be good on barges. Is this good for cars ??
Eastwood Rust Encapsulator
Advantages: Cheapest option.
Disadvantages: ??
Rust Killer
Advantages: ??
Disadvantages: ??
Old Jan 7, 2007 | 10:48 PM
spf72's Avatar
spf72
Not sure what you mean on 300 degree cure or toxitity for Por 15? I have done my frame and most underneath brackets and it was easy to use. I just finished several pieces I did today. Just use the prep they suggest - and do NOT get any on your skin as it only comes off when the skin wears off.
Old Jan 7, 2007 | 10:54 PM
rajsid's Avatar
rajsid
Sorry, I meant POR-20
BTW.. do you have pics of your frame painted with POR-15 ?
Old Jan 7, 2007 | 11:09 PM
72LS1Vette's Avatar
72LS1Vette
POR-15/POR-20
Rust Bullet
Rust Doctor
Disadvantages: ??
Zero Rust
Disadvantages: ??
Rust Killer
Advantages: ??
Disadvantages: ??
I have used both Rust Bullet and Rust Encapsulator. Not sure what you mean about Rust Bullet being less durable than POR-15. RB is pretty hard when cured. The only disadvantage I see in Rust Encapsulator is that it shows more brush overlap than RB. RB cures more slowly and tends to flow out more evenly.
Rick B.
Old Jan 7, 2007 | 11:31 PM
sperkins's Avatar
sperkins
You forgot one!
Old Jan 10, 2007 | 08:29 PM
spf72's Avatar
spf72
Sorry for the delay, been away. Yes I have some pics and have been meaning to post them as people seem interested in frame offs. I actually bought another frame and got that painted before I pulled the body. I am now doing all of the brackets and assorted stuff in por 15. I will try and firgure out how to post pics and then select a few of the many I have.
Old Jan 10, 2007 | 11:11 PM
68 NJConv 454's Avatar
68 NJConv 454
I vote for POR-15.
Love this stuff, their headquarters is 3 minutes from my job.
I painted every peice of metal my arms could reach.
I even painted some small brackets in 60 degree temps....shhhhhhh
To Rust Busters
By Michael S. Palmer | 2026-06-03 09:39:05
