I need to find a source that will verify what my engine is. I have the Block and Head numbers and would like to find out what the engine came out of. Someone in the past told me it was probably out of a 69 vette or camaro and that it is a 350. I'd like to know where I can find the information to cross-reference this for my records. I may not be doing a NCRS resto, but I want to have all the correct information just-in-case I decide to sell it years down the road.
Post the numbers you will find stamped on the pad at the front of the right head. These will give you the engine assembly date and code, plus the VIN deriviative of the car the engine was originally installed in.
Looks like the 1968 327 engine was a 2-bolt main, and that there were none made with 4-bolt. Is this correct?
No factory 4-bolt 327s.
What numbers are stamped on the stamp pad (machined surface on the block in front of the passanger side head)? Should be two sets of numbers stamped there.
Web-sites or other sources?
BW
Post the numbers on the block. I have a book called "Corvette by the numbers" which has all the Vette blocks listed by year.
