Question about 1981 Mono leaf..
Old Jan 9, 2007 | 06:25 PM
Flying Ace's Avatar
Flying Ace
St. Jude Donor '05-'06
Default Question about 1981 Mono leaf..
I just found out today that my 1981 does not have a mono leaf rear spring. I know this was the first year for that change.
My car is also one of the last St. Louis plant cars. Any chance they started building them with the mono leafs in Bowling Green, or is that just wishful thinking?
Old Jan 9, 2007 | 06:29 PM
ETM's Avatar
ETM
You mean you have a steel spring? Not a composite one? I believe that only 4 speed 81s got the fiberglass rear spring.Auto with the base suspension I dont believe got the steel version.I may be wrong on that.
Hope that helps.
Old Jan 9, 2007 | 06:33 PM
Xakk's Avatar
Xakk
From: http://www.100megsfree4.com/corvette/1980/vet81.htm
  • Corvettes with Turbo HydraMatic had a new fiberglass-reinforced monoleaf rear spring that weighed just eight pounds (33 pounds less than the multi-leaf steel spring it replaced).
  • The new spring eliminated interleaf friction.
  • Manual-shift models kept the old spring, as did those with optional Gymkhana suspension.
Old Jan 9, 2007 | 06:41 PM
Flying Ace's Avatar
Flying Ace
Correct, I have a multi leaf steel rear spring and it's an Auto trans.
Old Jan 9, 2007 | 09:20 PM
jomor's Avatar
jomor
My 81 4 speed with the gymkhana option has the steel multi leaf
Old Jan 10, 2007 | 01:15 AM
ETM's Avatar
ETM
OK I got it backwards.So base suspension Autos should have got the composite rear spring?
Old Jan 10, 2007 | 01:37 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
yes, auto = composite, 4-speed = steel = heavy.
ace, something is up with your car. it should have had composite regardless of bowling green/st. louis
BTW, there were never any 4-speed BG cars. not particularly important, just trivia.
Old Jan 10, 2007 | 07:57 AM
MN80Vette's Avatar
MN80Vette
Somebody probably replaced your original composite spring with a steel spring. How many leaves does it have? 7 or 9?
Old Jan 10, 2007 | 08:19 AM
Xakk's Avatar
Xakk
If the car was ordered with Gymkhana suspension, it'll have a steel spring, regardless of what transmission was in it. It's most likely an FE7 option car.
Old Jan 10, 2007 | 11:27 AM
Plane_guy's Avatar
Plane_guy
Same here Flying Ace. I have an 81 auto and one of the last from St. Louis. It has the steel spring.
Old Jan 10, 2007 | 11:46 AM
SJW's Avatar
SJW
I've done some work on an '81 automatic that has the steel rear spring.
Be well,
SJW
Old Jan 10, 2007 | 08:44 PM
MN80Vette's Avatar
MN80Vette
If it was ordered with the Gymkhana suspension (FE7) then it would have a 7-leaf spring. If it has 9 leaves, then it probably wasn't an FE7 car unless someone swapped springs.
To Question about 1981 Mono leaf..
