A/C drier 1980
Old Jan 9, 2007 | 10:13 PM
pdege's Avatar
pdege
Default A/C drier 1980
In order to remove the drier I had to cut the tailpiece on it. Now I am trying to remove the nut for the flare type fitting with no luck at all. I've used all the penetrating agents to no avail. Any ideas on how to break this tuffy loose?
I'm afraid to use heat because Al doesn't turn red like steel, it simply falls apart when it gets too hot.
Old Jan 10, 2007 | 07:51 AM
pdege's Avatar
pdege
ttt
Old Jan 10, 2007 | 09:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Heat...in moderation.
Old Jan 11, 2007 | 05:34 AM
pdege's Avatar
pdege
will propane get it hot enough?
Old Jan 11, 2007 | 09:46 AM
Easy Mike's Avatar
Easy Mike
Ought to. I would be wary of attempting to go with anyting hotter.
To A/C drier 1980
