Electrolytic Rust Removal
Old Jan 10, 2007 | 03:03 PM
c-3 envy's Avatar
c-3 envy
Default Electrolytic Rust Removal
Forgive me for butting in about rust again, but I found an article on electrolytic rust removal that sounds like it would be very useful for the smaller parts that would be difficult to blast. Essentially, the guy used a plastic trash can, rie bar and a 12v battery charger to make a rust removal tub effective for anything that can fit in a trash can.
http://www3.telus.net/public/aschoep...lyticrust.html
Old Jan 10, 2007 | 03:28 PM
Tommy Samuels's Avatar
Tommy Samuels
Default re: electrolytic rust removal
I did a lot of parts for a 61 MGA I was rebuilding. The process couldn't be simpler, but you need to undertand that it is "line if sight" since electricity follows the path of least resistance.
It is slow, but it works great. My set up used a 30 gallon plastic tote and some scrap sheet metal I had in the garage. Adjust the "speed" of the process by increasing or decreasing the surface area of the sheet metal or rebar to keep current below 6 amps to prevent damage to the battery charger.
Also don't put the charger clips in the solution or they will go away.
Old Jan 10, 2007 | 04:16 PM
c-3 envy's Avatar
c-3 envy
The line of site issue is why I like his rig. Put the part (attached to the negative) in the middle and rie bar (attached to positive) all the way around. Good line of sight and positive charger clips never contact the water.
Old Jan 10, 2007 | 04:36 PM
Billysvette's Avatar
Billysvette
This is kinda the same thing,what about them electric units that bolt to your car and battery and suppose to stop rust from forming,Do they really work?
To Electrolytic Rust Removal
