I Like These Stands!
Eddie
Eddie, why brother when a good set of 3 1/2 ton floors jacks do the job and are cheap and very safe. Those don't look safe to me I won't be under that car. Save your money for other vette goodies.
69 Camaro with a 3.73 12-bolt positraction rear axle and deep tone dual exhaust and no style trim package. Probably a Z/28 right? Looks like it might be Fathom Green. SWEET!
As for the stands - They look cool but not all that practical.
-Mark.
The design is VERY prone to buckling. There IS some relatively modest side load that will send the car crashing down.
If you want to attach to the wheel studs, you need a three point support as least as wide and long as a regular jack stand.
I suppose you could take an aluminum (or steel) wheel and flatten its bottom, and add height at the flat to provide the height you want if you really think you need to keep the weight on the suspension.
The car is a 1969 L-78 Camaro... Burnished brown with a black interior. It had a lot of work done at the same restoration shop that is doing my '69 Camaro. This car cleaned house at the fall 2006 Chevy/Vettefest from what I recall. Very cool car!
As far as safety... That display stand is made from 1/2" heat treated steel. I would be willing to bet that it is as strong if not stronger than the stamped steel jack stands that most people are comfortable using to work on their car.
Regards,
A concrete block will hold up a house. However, like all things in life, it has to be done the right way, not the bubba way.
A concrete block is ONLY strong in compression. This means the holes must be up and down, not sideways.
A concrete block is ONLY strong in distributed loads, not point loads. Your hammer is a point load. So is a steel frame resting on it.
Why do you think a 150 lb jackhammer can break a roadway when a 72,000 lb tractor trailer won't?
If you have a concrete block with the holes up and down (imagine that you can fill it with water), and you use a wooden board across the top to spread the load, that car will sit there until your fourth generation come along or the car rusts into and falls off.
Concrete blocks are like a lot of things. Some idiot comes along, uses it wrong and gets hurt (killed), and then everyone screams they aren't safe. Look at motorcycles, convertibles, sports cars, and so on.
