black denim vette
http://www.harley-davidson.com/wcm/C...r&locale=es_ES
click on VRSC 'night road special'...you'll see what i mean.
before he painted it yellow (with rustoleum) and was documented here. Try a search,,,good luck, Peace,,, MoosieTry this http://forums.corvetteforum.com/show...with+rustoleum
Hot Hues™ Hot Rod Black HHM-6400™ http://pc.dupont.com/Phantom/content/hh-short.html
Hot Rod Black is a 2K single stage matte topcoat with excellent satin gloss and color retention. Designed to achieve the required build and appearance in two coats, it provides outstanding chemical resistance, smooth appearance and may be air dried, or force dried by infrared or low bake.
Hot Activators and Reducers can be used with Hot Rod Black to achieve the ideal results based on shop requirements. For stripes or completes, Hot Rod Black is an ideal choice. It will not chalk or fade, so you can do it once, do it right - and go cruising.
* This product is not VOC compliant for some southern California markets. *
Hot Hues™ Hot Rod Black HHM-6400™ Application Guide
Hope it helps,,,,Peace,,, Moosie
P.S. http://www.performancecoatings.dupon...le=DirectLogin
I had a 71 Gremlin but it had the regular interior.
