Help decoding block number
Old Jan 11, 2007 | 08:35 PM
Q's 68's Avatar
Q's 68
Default Help decoding block number
Hey, all.
My block is original and has the VIN# followed by the following - V03IIHT. The second "I" may be a "T". Can anyone tell me what it translates to?
Thanks,
Q
Old Jan 11, 2007 | 08:42 PM
raider21's Avatar
raider21
Default Decoding
Corvette Restoration Guide says. . .
HT = 327/350 L79 withRochester Q-Jet, special camshaft and four-speed
Old Jan 11, 2007 | 08:47 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
V03IIHT can be decoded as follows:
V=Flint
03II=March 11, 1968
HT=1968 327Corvette 350 L-79 4-spd 4-Brl HP Hyd Cam
Old Jan 12, 2007 | 02:31 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
My 68' was built april fools day
TO401IM
was probhably on the line same time as yours.........
Old Jan 12, 2007 | 12:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
TO401IM
Nope. Your engine was assembled at Tonawanda on April 1st. It was then shipped to St. Louis before your Corvette was assembled.
Check the Time/Build date on the trim tag. If your car is I01 and your engine is 0401, you'll need to determine why they are the same day.
Old Jan 12, 2007 | 02:59 PM
427SIXPACK's Avatar
427SIXPACK
Check the Time/Build date on the trim tag. If your car is H01 and your engine is 0401, you'll need to determine why they are the same day.
OK HERE IT IS:
Trim Tag I 11 would be April 11th motor built april 1st, AWEFUL CLOSE
block cast # 3916321
head cast # 3917215
intake # 3937795
exhuast left # 3880827
exhaust right # 3880828
starter # 1107365
rear 2 AT 3 28 68W
trans p8c28c
Old Jan 12, 2007 | 03:18 PM
Easy Mike's Avatar
Easy Mike
[B]OK HERE IT IS:
Trim Tag I 11 would be April 11th motor built april 1st, AWEFUL CLOSE.../B]
Close, but correct since the engine assembly date must predate the time/build date on the car.
Engine assembly date on my sweetie is 4/9/68; time/build code is I20 for Saturday, April 20th but she probably wasn't finished that day. My girl came along after your car, but I'm betting your car had already been shipped by the time my girl was driven out to the lot.
To Help decoding block number
