I Hate Wires!!
I finished pulling the old harness from my 70 today. Now I want to replace the old guages with Phantom guages from Autometer.
1. Fuel Temp Guage: The standard guage has the sender wire and the 12V wire. The autometer guage has both those wire terminals plus a ground post. What am I missing? How was the fuel guage originally grounded?
2. Water Temp Guage: This seems to make sense. The original guage has the sender, 12V, and ground. The autometer has the same. I think I can simply tap the right lines and done.
3. Console Lights: Since the new guages have their own plug in lights with a 12V and ground connection, can I run the car without bulbs in the console lights? Also, and imortantly, are these grey single wires 12V? Can I tap for the positive terminal?
4. Ammeter: I want to use a Voltmeter in place of the Ammeter. What do I do with the B and B/W wires?
Any help would save my sanity!!
3. You can run the console without bulbs with no problems as long the wires in the lighting bulb sockets don't ground out, either behind the console OR drift inward to ground inside the console.
4. For the voltmeter, all you need to do is take any switched 12V wire and any gound.
2. Water Temp Guage: This seems to make sense. The original guage has the sender, 12V, and ground. The autometer has the same. I think I can simply tap the right lines and done. That's right, the green is the sender wire.
3. Console Lights: Since the new guages have their own plug in lights with a 12V and ground connection, can I run the car without bulbs in the console lights? Also, and imortantly, are these grey single wires 12V? Can I tap for the positive terminal? Yes. Yes they are 12v, depends on how big a draw you be getting from them. These are the instrument lights and fused from the fuse block with a low amperage fuse.
4. Ammeter: I want to use a Voltmeter in place of the Ammeter. What do I do with the B and B/W wires? Tape them up out of the way.
As far as grounding goes, just connect all the gauge's grounds together and connect to frame ground.
