Stone chips from front tires
Old Jan 14, 2007 | 12:55 PM
smbenn's Avatar
smbenn
Default Stone chips from front tires
Probably a dumb question but the previous owner put 255's all round on my 75, and I'm getting a few stone chips on the doors. Presume that this is because the tires are wider than the wheel arch?
Anyone else get this problem running 255's before I swap the fronts to 225?
Thanks!
Si
Old Jan 14, 2007 | 01:51 PM
Crunch-o-Matic's Avatar
Crunch-o-Matic
225 60s all the way around on my 73 vert and I have the same problem. Currently my car is getting painted and I plan to get those clear paint protector "decals" and place them in the affected areas.
I havent considered smaller tires; they might do the trick as well.
Cheers,
Crunch
Old Jan 14, 2007 | 02:52 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Are you getting the chips on the door or the panel right behind the front door....I'm getting mine on that panel....
Old Jan 14, 2007 | 04:15 PM
smbenn's Avatar
smbenn
Mostly the door but I'll need to check again (it's under cover now).
(BTW isn't it 225/70 or 255/60, not 225/60? If the latter won;t it affetc your speedo reading?)
Regardless, thanks for all your input so far!
To Stone chips from front tires
