emblem removal
Old Jan 15, 2007 | 03:56 PM
dabrogger's Avatar
dabrogger
Default emblem removal
how do i remove the crossed flag emblems on the front fenders of my 1977? I took off the nose and the gas tank badges and redid them with model paint and they look great. Only problem is now the side ones don't look nearly as good so I guess they're next. Thanks.
Old Jan 15, 2007 | 04:36 PM
Durango_Boy's Avatar
Durango_Boy
Can you strip and paint them while they are on the car?
Old Jan 15, 2007 | 06:34 PM
dabrogger's Avatar
dabrogger
I probably could but it would be much easier and neater to do them horizontally.
Old Jan 15, 2007 | 06:36 PM
Durango_Boy
My '77 didn't have side emblems so I cannot help. I don't know if they are pinned in or glued on.
Old Jan 15, 2007 | 07:01 PM
Duke94's Avatar
Duke94
Another trick to remove stick on emblems and such is to soak around the edges with "GOO GONE" spray gel then use a piece of nylon fishing line to cut through the sticky tape (between the emblem and the surface it's stuck to). I used this method when changing emblems on the fenders. No paint damage at all.
Old Jan 15, 2007 | 08:14 PM
Mark_Milner's Avatar
Mark_Milner
If they are like a '79, they are just glued on with this back junk. Thin putty knife and pop them off carefully. You are repainting anyway, so if you get a nick or two, you can fix it and paint.
Old Jan 15, 2007 | 09:55 PM
C3 4ME's Avatar
C3 4ME
My 79 was being stripped to fiberglass so I just pried them off with a putty knife. They are held on with adhesive, but they have 2 locating studs on the back of them.
Old Jan 15, 2007 | 09:56 PM
Durango_Boy
Use the Goof Off and some fishing line. That'll work the best and do it safely.
To emblem removal
