07:Pull out the cotter key and spin off the control arm mounting bolt nut. Now while supporting the control arm, tap the mounting bolt out of the control arm. When it is free, remove the control arm from the car.
Yeah Right!!!...Why do they publish such total Crap? ...They make it almost sound like a 5 min job!!!
At least this forum gives honest and truthful advice!!
Sawzall, S**t pile of blades, BMF hammer, patience and Lots of Beer!!!
77/350- the trailing arms, if you think of them as your forearm or legs pivot on your knees or elbows. Trailing arms pivot on the bushings. The bushings, as originals, or at least in 77 were rubber and as a matter of torque, age and conditions like road salt cause it to break down over time. The newer poly bushing are supposed to be a modern alternative, which I upgraded to but have not yet formed an opinon on. And of course the shims you see in the cavity bring the arms in and/or out -essential for a proper alignment. The old harware was steel which rusts into a sold mass and the new is stainless making getting into the cavity again much easier. The shocks take the brunt of the vertical abuse from trailing arm to frame. Remembering that the axels are attached from the rear to the wheels (on the trailing arm) there is but one brace on either side that restricts all other horizontal movement. So you have side to side and up and down energy which translates into a semi rotational energy. But guess where all that movment or energy is tied to - the trailing arm bushings. So if I were to define the trailing arm I'd say it does all the above.
chuck
Man I really don't want to do this to mine. Can you change the yokes and service the rear end without removing the trailing arms? I think my bearings are actually okay.
Ahem to the pile of blades. I've gone through 6 blades trying to cut off the shock mounts after a futile attempt to beat them out with a BF sledge. This requires 4 cuts (2 each side) and I'm only through 1.5. Saturday I had the stupid idea that since everything else was apart I could simply remove the trailing arm and a least have better access to the mounts. I quickly found that while the bolt comes of no prob, the trailing are bolt is rusted into the sleeve just like my shock mount. By the way, how do I tell if the TA bushing is bad? Play up and down? I know there is a little side to side....
What's up with the sawzalls here, have some patience. I have removed many of these arms and NEVER had to use a sawzall. The cars ranged from rust piles to drivers to nice maintained cars. They all came out with some patience. The trick was to use a small angle air wrench and get that bolt spinning. Once it's spinning it'll come out fairly easy w/ a long pair of pliers and a 3 jaw grabbing hook thingie (what are they called, pull lever at the end and the 3 dr. octopus jaws open, release to close???) Also, some rost off ice does miracles.
Geeez, I guess I must be livin' right. Just pulled my trailing arms yesterday to change the original rubber to poly bushings. It took about an hour per side and most of that was spent drinking a couple beers and watching the COT's duke it out while the liqiud wrench did it's thing. No sawblades involved either.... of course my frame has almost no rust on it. No salt on the roads down here in Louisiana you know.
Now...all I got to do is get the old bushings out.
How do you get to the inside of the pivot bolt, pull it out, and put a new one in? The brake line bracket is in the way? The nut is easy enough to get to.
click/enlarge
i always "punch" mine out with a air hammer and pointed bit...normally take about secs per side
i think the key is to take loose the spring so theres no pressure, and support the trailing arm assembly woth a floor jack
Thanks JustForFun,
The problem I see is that the inboard side of the pivot bolt is "boxed in" with frame obstructions to include the brake bracket, preventing a human hand from reaching in to pull the bolt out and insert the new bolt. Hopefully I am overlooking something here. At wjat angle are you guys attacking this bolt at when putting in the new one?
Thanks JustForFun,
