Vehicle in storage
Old Jan 24, 2007 | 12:59 PM
isawdan's Avatar
isawdan
Default Vehicle in storage
I have a 1980 L82 in storage . I try to run it at least every couple weeks. With the salt still being on the roads I am forced to wait longer in between outings. Does any one know how long is too long for a Car to sit without being driven . The oil change is fresh . Thanks D.V.
Old Jan 24, 2007 | 01:12 PM
kylelm's Avatar
kylelm
I have been told they can sit all winter as long as the oil is changed b4 storage. Some like to put the car up on jack stands too. You should also disconnect the battery if you havnt done so already. And yes, start it weekly or every other.
Old Jan 24, 2007 | 01:15 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
If you drive her every two weeks and she's kept in nice warm storage, you're fine. Make sure you at least bring the engine up to temp when you do take her out to circulate the fluids and stretch her legs.
Left unattended, bad stuff happens,..rust (in weird place like ring and pinion gears), cracked tires, dead battery, leaky breaks, etc.
Old Jan 24, 2007 | 02:39 PM
Toms82's Avatar
Toms82
Default storage
Hi,
I'm from the North East, so my Vette goes into storage in the Fall. I fill the tank, change the oil and over inflate the tires a bit. I also pull the battery and put it on a float charger. Then, I wax the car and cover it. I've had the car for five years and this storage method does not seem harmful. I do have a heated, dry storage area, which helps.
Good luck with your Vette,
Tom
Old Jan 24, 2007 | 03:54 PM
another-user's Avatar
another-user
mines an outside car and sits from about november to april. i start it up about once a month and move it back and forth in its spot if i can. normaly cant because theres too much ice and snow.
i just keep a full tank of gas in it, put a cover on it, and unhook the battery. havnt really had a problem with it yet. storage wise that is....
Old Jan 24, 2007 | 04:25 PM
FKING1's Avatar
FKING1
Stored one of my cars for 2 years with oil change, full tank with Stabil, Battery Tender and car cover. Car started right up and I drive it now every summer. There is no need to start a properly stored car.
Fred
Old Jan 24, 2007 | 04:28 PM
Jims79's Avatar
Jims79
Fred
starting a parked car and not driving it is worse then not starting at all. The only thing you are doing is charging the battery and a tender can do that for your.
Old Jan 24, 2007 | 04:52 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
I park mine November 1st every year. Just disconnect the battery and walk away. I don't touch them until April 1st or so. They fire right up no problem. Then the oil gets changed, not in the fall. I never start them at all through the winter. I couldn't get to them if I wanted to. They are buried behind lots of RVs and muscle cars and motorcycles.
Old Jan 24, 2007 | 08:23 PM
Mike Ward's Avatar
Mike Ward
Please stop doing that. All you're doing is putting extra wear on a cold engine.
Cars can sit for years without deteriorating.
Old Jan 25, 2007 | 07:20 PM
isawdan's Avatar
isawdan
Thanks For The Valuable Info . I Just Took Her Out Today. Ran Up To Full Temp. This Car Flies With Ice Cold Air Going Into The Intake. D.V.
Old Jan 25, 2007 | 10:25 PM
TimAT's Avatar
TimAT
Default Storage
This old Gentleman sat for 28 years- on the tires. New battery, fresh gas, (well ok, it leaks a bit), changed the oil, and started right up. I had to replace 3 "freeze plugs" that had rusted thru, but it runs just fine.
"24 Model T- the only thing not original is the color of the wheels..
Old Jan 26, 2007 | 11:00 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Once mine goes into storage, I don't start her again until Spring. Like those above have said, it does more harm than good to start her up and letting her run for 20 minutes. An oil change, a full tank of gas with Stabil, disconnection of the battery, and a car cover lets her go into hibernation from Nov 1 to Apr 1 each year.
Old Jan 26, 2007 | 05:59 PM
Procrastination Racing's Avatar
20 minutes, even 30 minutes, won't usually get the CAR up to temperature, even if the engine is. You need to heat the exhaust so it doesn't rust off from moisture you pump through it. The transmission and rear end also need to be heated and oil circulated.
As long as there is no snow on the ground, or wet roads, it doesn't hurt to run the car out and around town for an hour to warm things up, circulate lubricants, and give yourself a charge. Doing this every month or two is better than sitting the whole time or starting and running in place for 30 minutes every week.
The best condition my Corvettes ever were in was when they were driven weekly, even through the winter. What got to them was sitting.
And taking them out for a ride every few weeks tends to keep the mice out.
Old Jan 26, 2007 | 07:03 PM
redwingvette's Avatar
redwingvette
Sta-bil in the tank, fog the motor just like I do the boats, disconnect the battery, and wait for spring.
Old Jan 26, 2007 | 09:06 PM
Matt O's Avatar
Matt O
The only other thing that I did was put 4 mil plastic down on the garage floor before I parked the Vette. The plastic keeps moisture down and I never saw any signs of rust anywhere...
Old Jan 27, 2007 | 09:02 PM
Mick42767's Avatar
Mick42767
OK, but how do you take the car out in spring? I keep reading about "priming the engine" before turning it over. What does that mean exactly?
Old Jan 29, 2007 | 09:28 PM
SEVNT6's Avatar
SEVNT6
Mine won't start unless I give it a squirt of gas, so on that first crank of the season I always just let it turn over until I see the oil pressure gauge come up. Then I hit the gas a couple times and off she goes. Been doing it like this for last 29 winters.
To Vehicle in storage
Old Jan 29, 2007 | 09:37 PM
bertmeister's Avatar
bertmeister
Why not just drive the car all year. Any salt or dirt that gets on the car will wash off.
Old Jan 29, 2007 | 10:58 PM
You've never lived in Chicago in the winter. They must dump 5 tons of salt for every man, woman, and child in that area. I used to wash my Suburban every couple of days from all the salt, if the roads were wet. Nasty stuff, the Suburban spent its whole life in Florida up to that point and in one winter it began to suffer nasty rust in the wheelwells like Suburans get.
However, out in Plainfield, he should have some small roads he can get it out on to run it an hour or more every month. That is all it needs. The main thing is drive for long enough to heat the mufflers to dry them out. Then you know everything else is, too. Of course, the temp gauge needs to get at least to the 180 mark.
If not, then you are not getting it hot enough to boil the moisture out of the oil and are not doing any good. With winters below zero, you could have a problem getting it hot enough. If that happens, change the oil, pull the battery out, and park until you have 40 degree weather.
Old Jan 29, 2007 | 11:16 PM
68/70Vette's Avatar
68/70Vette
When you start up an engine, the exhaust gas contains water as a by-product of combustion. With a cold engine and exhaust/muffler system the water vapor in the exhaust condenses into liqiuid water. So a brief run on a cold engine just adds water into the oil, exhaust pipes and mufflers. You need to run the engine until the exhaust pipes and mufflers are above 200 degrees F. This way, water vapor created will be exhausted and any liquid water in the mufflers will be evaported.
....Also, if I've got this right, all the water vapor in engine exhausts is causing the ocean levels to raise and also glaciers to melt.
