O/T Cooling system
Old Jan 24, 2007 | 02:25 PM
Toms82's Avatar
Toms82
Default O/T Cooling system
Hi,
This is off topic, but I know you guys know a lot about cars. 1999 Chevy Cavalier 4 cyl A/T A/C. Around town temp gauge is normal (middle of gauge). On highway, temp slowly drops to cold after a few miles. Heater output drops off, indicating to me the gauge is accurate. I replaced the OEM 180 degree t-stat with a 195 with little improvment.
Anyone have any ideas? I'm stumped.
Thanks,
Tom
Old Jan 24, 2007 | 03:40 PM
76custompaint's Avatar
76custompaint
Just put it down a gear on the highway, temps will stay right up there
76CustomPaint
P.S. Also you could switch it out to 70/30 antifreeze/water, that will raise the temps a bit.
P.P.S. My 85 Mazda 626 would never get up to temperature when it was really cold out, I think the problem is there just isn't enough engine there to keep it warm..
Old Jan 24, 2007 | 04:08 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
Its crude but I use an old rug keep a eye on the first couple of times to get the temp right but mine goes on in nov and comes off in feb watch running in heavy snow it will get warm quicker.It will keep you warmer to.
Old Jan 25, 2007 | 07:17 AM
Toms82's Avatar
Toms82
Hi,
Thanks for the replys. 76 custompaint, I had a 1984 Mazda 626. Man I loved that car! It was burgundy with a power sunroof and that cool dash vent that moved back and forth. Thinking back, you are right, the heater wasn't very good. Lon Wayne, that's a good idea. I'll block off part of the radiator and see if I can get the temp up.
Thanks again,
Tom
To O/T Cooling system
