I don't think anyone is repo-ing these parts. I'm sure you can pick up a good used one at Paragon Vintage. I've been to their place and they have a lot of used parts. http://www.corvette-paragon.com/
Dino, i have freed up those rusted linkages to make them work smooth using a wire wheel on a dremel tool. did you take yours apart to clean it up? If the parts arent missing/broken that is an easy fix. Once you get it free put some white grease on it to keep it from rusting fast.
Ed,
I have sprayed it was some liquid wrench to see if it will free up. I will try the dremel idea next. The linkage is all there, just frozen in place.
