Can someone run these numbers?????
Old Jan 25, 2007 | 09:23 PM
69any1's Avatar
69any1
Default Can someone run these numbers?????
V0103hv
Cast# 3932386
L128
Thankyou
Old Jan 25, 2007 | 10:05 PM
Howy's Avatar
Howy
Here you go
v=flint engine plant
01=january assembly month
03=3rd day assembly day
hv=passenger car 350 with 255 horsepower and a turbohydramatic 350
3932386=1969 block,chevrolet documentation shows that this block was 4 bolt only but according to my chevrolet by the numbers book, 2 bolt could exist as well.
L128=casting date.L=december
12=12th day
8=1968
Hope this is what you are looking for
Howy
Old Jan 26, 2007 | 07:52 AM
69any1's Avatar
69any1
Can someone else check this to make sure this is right...
I have a 1969 350/350 manual
thanks
Is it possible it could be a HW???? I heard these were stamped by hand.. My old man vows this is the original engine....
Will my Vin fall into a certain range that would confirm that its the right engine???
Old Jan 26, 2007 | 08:24 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No HV codes for '69s. Last Corvette use for HV was 1965 327/350hp. My Chevrolet V8 pocket guide lists HV for a 69 350 for use in passenger cars.
Check your number again to make sure the code is actually HV. The VIN derivative should also be stamped on the pad.
Old Jan 26, 2007 | 07:14 PM
Howy's Avatar
Howy
I checked my book tonight and could your letters be HY because in 1969 this was a corvette 350 with 300 horsepower manual transmission and a rochester 4bbl carb.
All your dates seem corect,block is correct.Have you found the vin stamp?
Let us know how this turns out.
Howy
Old Jan 26, 2007 | 09:05 PM
69any1's Avatar
69any1
this what i got...
There is no vin stamp.. at least there isnt one visible.. Is it possible a block could me miss labeled since these were done by hand?? i dont know im stickin to my 350/350 story
To Can someone run these numbers?????
