76 dash lights not working, need advice
Old Jan 27, 2007 | 12:03 PM
dougkdp's Avatar
dougkdp
Default 76 dash lights not working, need advice
Any advice before I go purchase a headlight switch? I want to make sure I exhaused all other possibilities before spending the money. I've looked through other threads, and here's what i've verified.
- Headlights work fine
- blinker lights work
- brake lights/backup lights work
- I tried turning the **** on the switch to verify its not a bonehead mistake
- Replaced fuse in fuse box
Thanks, and any other misc things to replace while I have this apart?
Old Jan 27, 2007 | 12:17 PM
TimAT's Avatar
TimAT
Sounds like you covered it. I'd buy a box of whatever bulbs the panel lights use. While you have the dash out, replace the bulbs you can reach. Beats having to open the dash again.
BTW: Did the interior light come on when you cranked the panel dimmer?
Old Jan 27, 2007 | 01:20 PM
Duke94's Avatar
Duke94
Do any of the dash lights work? A/C heater illumination, transmission indicator? If not, check the inst. panel ground which is located on the left hinge pillar. Check for power at the fuse (check both sides). If there is no power, then the light switch is kaput. If there is, gotta be a bad ground or main power feed wire (on my 78', it's green from switch to fuse block and grey from fuse block to gage clusters).
Old Jan 27, 2007 | 11:00 PM
Steve COSD's Avatar
Steve COSD
Replace the light switch. Was the fuse blown? If so the wiper on the reohstat spring has too much play causing an arching condition.
Good Luck Steve
To 76 dash lights not working, need advice
