whats up with my headlights?
Old Jan 27, 2007 | 11:49 PM
whoodiestyle's Avatar
whoodiestyle
Default whats up with my headlights?
actually more like whats down.. anyways my headlights don't want to go up anymore unless done manually but go down fine. anyone know how i can fix this?
Old Jan 27, 2007 | 11:56 PM
Durango_Boy's Avatar
Durango_Boy
More than likely you have a vacuum leak, and you don't have enough vacuum to raise the lights. A more expensive problem would be that you need to replace one or both or the headlight vacuum relays or actuators.
Start checking all your under-hood vacuum lines. Check all the way down tot eh tiny ones that operate the heater core valve and wiper door if you have one.
Old Jan 27, 2007 | 11:58 PM
rihwoods's Avatar
rihwoods
Might be just a check valve...I have to sit a couple minutes running engine to get get my 78 right side up...but they both slam shut together...
Just not high on the list....yet..
Old Jan 28, 2007 | 09:43 AM
schmegeggie's Avatar
schmegeggie
Mine take about three seconds to come up. I've been told that's normal. Check for leaks. Replace lines that look like they're going bad, or need it. These vacuum systems can be great vehicles for spauning gray hair!
Old Jan 28, 2007 | 09:44 AM
Durango_Boy
Get a vacuum diagram for your car and a hand vacuum pump with a gauge. Start checking things from the motor out. Test every check valve, and every terminal end. Just go slow and mark what you can if you get confused.
Old Jan 28, 2007 | 09:45 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
ANSWER:
It's too warm in FLORIDA to have headlights up & on ........
May i suggest to continue to play with them manually, untill they go on........ ( . ) ( . )
Old Jan 28, 2007 | 10:10 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I am going to guess that it is the "Witches Hat" that is bad in the actuators. Here is a link to a website that has some pretty good troubleshooting ideas on how to get the lights back to working correctly again. Look for the link on the left side of the page Vacuum Troubles.
Old Jan 28, 2007 | 11:18 AM
Tall Boy's Avatar
Tall Boy
Replace the seals in your actuators, and I bet the problem would goes away. It is a cost of about $20-30 so if you don't see anything else wrong it would be the first thing I would replace. After replaceing mine the lights go up in less then a second or two
Old Jan 28, 2007 | 12:52 PM
69L46vert's Avatar
69L46vert
http://lbfun.com/Corvette/Tech/vette...m%20System.pdf
Old Jan 28, 2007 | 10:42 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
If I read your post right...............
Headlight switch doesn't raise lights, but
the override does?
Then the headlight switch needs looking at.
hoses, switch itself.................
If I read it wrong.......................never mind
Old Jan 29, 2007 | 02:40 AM
saudivette's Avatar
saudivette
Vacuum sucks (pun intended)! If/when you get tired of checking for leaks and replace all the vacuum related antiques, try this...
http://www.mcspeed.homestead.com/Our_Products.html
To whats up with my headlights?
