Photochoppers...
Old Feb 6, 2007 | 09:05 PM
Durango_Boy's Avatar
Durango_Boy
Default Photochoppers...
Hi guys. I have a copy of Photoshop CS2 installed and ready to go. I have opened it once to update it, but never tried using it. I have no clue where to begin.
I want to learn how to make animated GIFs.
Who can walk me through it?
I will have the images I want to use in a folder all by themselves and ready to go.
Thanks.
Old Feb 6, 2007 | 09:24 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Not that easy to walk through without being in front of the computer its worth it to learn. I am learning to edit
camcorder video
Old Feb 6, 2007 | 09:31 PM
Durango_Boy
camcorder video
Yeah, video editing software is next on my list.
Old Feb 6, 2007 | 10:50 PM
Muddywaters's Avatar
Muddywaters
Hey Durango... I picked up a copy of (Photoshop CS2, Classroom in a book) at Costco this weekend. Costco sells it for 28.99 and is listed at 49.99 on the back cover The book comes with a CD and works you through every chapter with lessons... Looks like the go!!! Oh, the book is written by ADOBE!!! I have already read the first chapter and must report... Looks great!!! Can't wait for the CD! Muddy
Old Feb 6, 2007 | 10:55 PM
Durango_Boy
Let me know when it shows.
Old Feb 6, 2007 | 11:00 PM
Muddywaters
I'll do that...you let me know too! Must be the cool weather slowing the snail mail Muddy
Old Feb 6, 2007 | 11:02 PM
Durango_Boy
Yeah, I mailed that long enough ago that you should have it by now.
Old Feb 6, 2007 | 11:08 PM
Muddywaters
Must be right around the corner...as yours. I mailed the Cali-T, well, Joanne mailed it... Monday, a week ago! ummmm. She'll come! Muddy
Old Feb 6, 2007 | 11:09 PM
Durango_Boy
I'll for sure let you know. Thanks again by the way.
Old Feb 6, 2007 | 11:26 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Not even sure you can make an animated gif in PS. Anyway there is nice little program you can probably get for free call Gif Animator, pretty straight forward and easy to use. PS has a very steep learing curve
http://www.jhepple.com/gif_animator.htm
I use Ulead Gif Animator:
http://www.ulead.com/ga/runme.htm
Old Feb 6, 2007 | 11:29 PM
Durango_Boy
Thanks...I may check those out.
Old Feb 6, 2007 | 11:32 PM
chris73cpe's Avatar
chris73cpe
I've only used it to pull animated gifs apart, but I think Imageready is better built to handle that kind of thing. It installs with photoshop, so you should already have it. Every frame of the animation will be saved as a seperate layer and there will be a seperate window that lets you specify the frame rates and that kinda stuff. I know they added support for animated gifs in one of the later photoshop versions, but I'm sure how developed the feature actually is.
Old Feb 7, 2007 | 08:53 AM
JUSBAD's Avatar
JUSBAD
Hey Durango, I got my CD speedy fast, thanks again,
now if I could also learn how to do the handy work on this thing
Old Feb 7, 2007 | 10:30 AM
Durango_Boy
Did the install go okay then?
Old Feb 7, 2007 | 11:15 AM
GD70's Avatar
GD70
Image ready is what you need to use.
Just be wary that Photoshop will require you to register with ADOBE. If your serial numbers are used by someone else there could be a problem. When you boot up for the first time you usually are required to register before you can use the program. One way around this is to disconnect your modem when you boot up PS so Adobe's servers don't detect 2 copies in use at the same time. Not like the good old days of being able to make copies without any problems. Just thought you guys should be aware of this.
Glenn
Old Feb 7, 2007 | 11:37 AM
Durango_Boy
Glenn
Don't worry, none of us have the same serial number, and each can register in their own name and receive updates.
Old Feb 8, 2007 | 03:07 AM
saudivette's Avatar
saudivette
Thanks.
Mate, that's a heavy duty program that's probably a bit OTT for making animated gifs. I've never used Photoshop to do that, I use a simple little program called GIF Construction Set Professional by a mob called Alchemy Mindworks. It's real easy to use, far easier than Adobe would be... (IMHO of course)
To Photochoppers...
Old Feb 8, 2007 | 08:00 AM
JUSBAD's Avatar
JUSBAD
Install went smooth, I just want to be able to make those cool
overlaying pictures, kind of like a collage.
Old Feb 8, 2007 | 11:02 AM
Durango_Boy
Hmm...I have a Microsoft GIF animator right now that I've been playing with and it seems very dated and I cannot make high resolution GIFs. The images always end up very grainy.
Is that program you use free?
Old Feb 8, 2007 | 04:16 PM
saudivette's Avatar
saudivette
...Is that program you use free?
No, but it's "real cheap" to register. Pm me...
