Cornering Lights for '77
Old Feb 7, 2007 | 07:29 AM
PhotoVette1's Avatar
PhotoVette1
Default Cornering Lights for '77
I miss the cornering lights from when I had an '81 Vette.
So, I came up with an idea for adding them to my '77.
What I thought of doing was adding a pair of these 1156 3-watt white LED bulbs (one on each side) to the heading bezel.
These bulbs are much brighter then the standard cornering bulbs.
I'm not too worried about drilling this piece as they are sold new aftermarket and can be replaced.
As for wiring it, I'd use 2 courtesy delay light modules and hook it into the hiring harness at the turn signal bulb wiring socket.
Any thoughts?
Old Feb 7, 2007 | 07:37 AM
Tommy Samuels's Avatar
Tommy Samuels
Are they lit all the time or just when the turn signal relay is energized?
I don't mean will they blink, but just come on when you move the turn signal lever either way to energize the circuit?
I see a small problem with on all the time being an annoyance to other drivers
Old Feb 7, 2007 | 07:40 AM
PhotoVette1
The way I see it is that when the turn signal comes on, the delay timer energizes the cornering bulb. Each time the turn signal flashes, the delay timer resets. When the turn signal is disengaged, the delay timer is not reset and will shut the cornering bulb off in 10-20 seconds--just like the interior courtesey lights.
Old Feb 7, 2007 | 08:54 AM
Tommy Samuels
Very nice
I really don't think it would detract from the looks at all and would really improve night-time safety
Wat des the project cost?
Old Feb 7, 2007 | 10:21 AM
PhotoVette1
Very nice
I figure $50 for the bulbs, $15 for the sockets, maybe $20 for a delay module of some sort. So, around $100 tops. I ordered the stuff, so I'll post when I get it installed.
Old Feb 7, 2007 | 11:36 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I like it!
Report back on how well it works...
Old Feb 7, 2007 | 11:41 AM
Durango_Boy's Avatar
Durango_Boy
I like the idea, but I can image it will look something like when a lens is broken and you see someone's bright white bulb behind it. Maybe French it and add a small round lens, white or amber. I like the idea though.
Old Feb 7, 2007 | 01:29 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
The thing I see is no one will see the little lights because ,I dont know about you but the last thing I look at Is the headlightwhen it s lit Put it in the bumper as far to the edge as possible at least they will be useful.
Old Feb 7, 2007 | 04:08 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i like that idea keep us posted.
To Cornering Lights for '77
