rivots
Old Feb 8, 2007 | 07:37 PM
onaqwst's Avatar
onaqwst
Default rivots
what is the name of the rivots that are flush/domed on each side..... i think they used them in aircraft applications..... i have a project and need a rivot look on both sides......(i.e. aluminum to leather)
b
Old Feb 8, 2007 | 08:17 PM
SIXFOOTER's Avatar
SIXFOOTER
Most aircraft use a countersunk rivet to bond skin to frame
Old Feb 8, 2007 | 08:39 PM
Hammerhead Fred's Avatar
Hammerhead Fred
b
They are called, simply enough, "solid rivets".
Old Feb 8, 2007 | 08:44 PM
Durango_Boy's Avatar
Durango_Boy
As mentioned above, solid rivets, but the style is 'Round Head.'
There are a lot of different styles of solid rivets, and most are flush or countersunk.
Old Feb 8, 2007 | 08:48 PM
onaqwst's Avatar
onaqwst
i just searched through mcmaster and found them...
next question is the tool needed
what i plan on doing is bonding 1/16 or 1/8 aluminum with leather..... space would be limited since i'm making a bag line for my clothing line... so picture a thin box that is about 2-3" wide and 12" tall..... the thin sides are aluminum and the front/back will be leather..... so i would need to figure out how to rivot the lower rivots once it is assembled.... unless i can figure out another way of doing that detail...i want to stay with rivots for the look of my :2:37am: line......
i want to prototype all my work myself so the detailing is important....
b
Old Feb 8, 2007 | 09:07 PM
onaqwst's Avatar
onaqwst
duh...
i can just rivot on the outside instead of trying to use the tool on the inside...that is if the rivot looks the same from both ends after install... i would need the better side on the outside...
is there any other tools that would help in this process.... for instance i seen a tool the you need to use a hammer to flatten the rivot... and the air ones seem the have to wrap on both side of the rivot.... any ideas
b
Old Feb 8, 2007 | 09:17 PM
Hogwild's Avatar
Hogwild
[QUOTE=Durango_boy;1558877794]As mentioned above, solid rivets, but the style is 'Round Head.'
they are called button heads in aircraft .
ntq
Old Feb 8, 2007 | 09:33 PM
mobjack68's Avatar
mobjack68
www.bylerrivet.com....you are looking for "blind" or "mating" rivets.
Alloy / Material steel, brass plated
Diameter of Body 5/32"
Head Diameter 5/16" (.312)
Head Style oval hd.
Length of Body 13/64"
http://www.bylerrivet.com/view_detai...46&to=category
will get you to a pic of "tubular" rivets...
good luck
To rivots
