what makes a C3 SO heavy?
Old Feb 9, 2007 | 10:36 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I haven't weighed, but simple driving tells me my 73 Vettes are at least 10-15% heavier than my 69 Camaros. The biggest difference has the be the full frame/birdcage vs. the unibody. Secondary factors are the IRS, front bumper on my 73, 4 wheel discs brakes (vs. front disc, drum rear on the Camaros) and doors.
You'd think a two-seater fiber-glass car would weigh less.
But the Vettes win the weight distribution contest, hands down!...this is 'somewhat' important as well.
Old Feb 9, 2007 | 10:40 AM
mr nasty's Avatar
mr nasty
Originally Posted by MYBAD79
1lbs of fiberglass is as heavy as 1lbs of steel.
Old Feb 9, 2007 | 10:49 AM
Hogwild's Avatar
Hogwild
Originally Posted by randommj
True its a cast Iron block, 350 or up, but its got a fyberglass body, a 68 chevel will weigh bous 3800 but thats a steel body, shouldent vettes b sugnificantly lighter my 74 weighs 3300
randommj
get rid of that spare tire and carrier. then put aluminum heads and hooker side pipes also a non stock hood will save about 40 pounds too. . then pick up a small electric tire pump and patch kit
i kept the jack , i don't know why? store all of that in the doors of the floor behind your seat more than enough room also have the jumper cables and hand tools just in case . 72 vert still weighs just under 3150. if your going to drag it behind a trailer don't worry about the weight
ntq
Old Feb 9, 2007 | 11:00 AM
randommj's Avatar
randommj
i had no idea, thanks guys! bout how heavy is all the fiberglass on the car in total(bird cage included)
randommj
Old Feb 9, 2007 | 11:27 AM
Twin_Turbo's Avatar
Twin_Turbo
The fiberglass isn't that light at all. I could weight the front and rear clip completely, the weight would be a tad too little as I cut off some pieces in the back and don't have inner fenders on my front clip. The rear glass (bubble glass) is very heavy as is the windshield.
The floor is pretty heavy too, the birdcage itself dunno...I can weigh that also. All these pieces however are easily carried by 2 people. probably also by 1 person but too large and cumbersome to handle
Old Feb 9, 2007 | 11:31 AM
randommj's Avatar
randommj
oh u dont need to weigh it i was just wondering i thought fiberglass was a FAIRLY lighter material, but i was wrong if you are planning to weigh it already go on a post it but dont go out of your way,
randommj
Old Feb 9, 2007 | 12:59 PM
early shark's Avatar
early shark
My white '71 LS6 coupe in absolutely stock condition, weighed at scales and certified the weight. Came in at 3340lbs, with no fuel in tank, well virtually no fuel (was running on fumes, practically) and no one in car.
Old Feb 9, 2007 | 01:21 PM
Twin_Turbo's Avatar
Twin_Turbo
I'll probably just weigh it anyway, hardly any trouble. I have the rear clip off and the front clip also. I'm curious as to how much it really weighs.
Old Feb 9, 2007 | 01:26 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...ever pick up a '63-'79 rear end??? Without anything attached to it??? It's a ball breaker.
Old Feb 9, 2007 | 01:27 PM
randommj's Avatar
randommj
ok cool! post it when u get the chance, at least with it being so heavy i dont hav to worry bout any one litterally picking up my car and taking it, its been known to happen...here
randommj
Old Feb 9, 2007 | 01:52 PM
Brooklinite's Avatar
Brooklinite
Originally Posted by 1Cool80
Yep. These cars hold a lot of fuel too.
Then how come I have to fill it up so often?
Old Feb 9, 2007 | 01:55 PM
randommj's Avatar
randommj
i dont know wut MPG ur getting BUT 8 MPG DOSENT help.
ranodmmj
Old Feb 9, 2007 | 01:56 PM
  #33
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My PT Cruiser weighs more than my '80, I don't think they are that heavy when you start comparing, it also weighs about as much as a new Z350 too
Old Feb 9, 2007 | 02:09 PM
  #34
carl a's Avatar
carl a
and a pound of feathers weighs the same as a pound of lead
Old Feb 9, 2007 | 02:21 PM
  #35
Tall Boy's Avatar
Tall Boy
I have heard that 40 pounds off your car is like adding 1-2 hp.?
Old Feb 9, 2007 | 02:25 PM
  #36
panic's Avatar
panic
[QUOTE=Twin_Turbo;1558885231]..... The raer glass (bubble glass) is very heavy as is the windshield.
today i took off the windshield to replace it with a lexan one, well..actually i thought the oem one was much heavier then it actually is...it's about 18/20 lbs (against the lexan that is not more then 6/7 lbs)...
Old Feb 9, 2007 | 02:28 PM
  #37
panic's Avatar
panic
i took exactly 650 lbs off my vette...so i should have well over 100 hp of power to weight savings achieved, on top of the 570hp of the engine itself
To what makes a C3 SO heavy?
Old Feb 9, 2007 | 02:30 PM
  #38
panic's Avatar
panic
it's not only a power to weight iussue...a lighter car brakes and turns on bends better then a heavier one...so not only it's faster but it's also more driveable
Old Feb 9, 2007 | 02:36 PM
  #39
73, Dark Blue 454
I've heard said that on a typical street car, every 100 lbs is worth about tenth in the quarter.
Old Feb 9, 2007 | 02:37 PM
  #40
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
What is the advertised weight of say a 69 or 70-72 Camaro?
