Oil filter Magnet
Old Feb 9, 2007 | 11:40 PM
supercalvin's Avatar
supercalvin
These were the ones I was looking at in the MidAmerica catalog
http://www.madvet.com/shop?frame=4.29
and
http://www.madvet.com/shop?frame=4.3857
I was having one of those moments where I was placing a small order and was paging throught the catalog double checking. Making sure there wasn't anything I couldn't live without.
Old Feb 10, 2007 | 12:34 AM
MIKER's Avatar
MIKER
These pictures show the debris captured inside of the filter housing with magnets from a computer hard drive stuck to the outside. It was from the first or second oil change on my current engine back in 2001.
It may not help anything but it didn't cost anything either.
Old Feb 10, 2007 | 12:58 AM
noonie's Avatar
noonie
Originally Posted by onaqwst
hitting switches in my 64 impala
Goood one maaaan
Old Feb 10, 2007 | 01:13 AM
noonie's Avatar
noonie
Originally Posted by redc3
whats hydraulics got to do with an internal combustion engine? two tottaly different animals.
The old old VW bug did not have an oil filter but a screen ( which was never touched), but did have a magnetic oil drain plug.
http://www2.cip1.com/ProductDetails....C%2DC10%2D5242
Also look here http://www.vescor.com/hydraulic_acc43.htm It is more useful at the oil pan than the filter.
Old Feb 10, 2007 | 01:21 AM
75coupered's Avatar
75coupered
Just a tip, I have a drain plug magnet, but also use an old speaker magnet on the filter case itself. These are the round O type magnets used on audio speakers, say 3-4" in diameter. Because they are O shaped, they seat very well on the bottom of any spin-on oil filter, and due to their large size they grip well and stay in place as well as attract alot of particles. Best of all, they are easily transferable from car to car.
So next time you replace one of your faulty car speakers, salvage the magnet and attach to your filter. Cheap insurance.
Old Feb 10, 2007 | 11:21 AM
Durango_Boy's Avatar
Durango_Boy
I have had a lot of trouble doing that without breaking the magnet. How's the best way to separate them?
Old Feb 11, 2007 | 12:44 AM
75coupered's Avatar
75coupered
Durango, they best method I've used is to soak the assembly in some solvent, usually the magnets are adhered to the speaker case, lacquer thinner works well, as does paint stripper, just let it sit for a while and then try to tap it off with a wooden dowel around the perimeter.
Old Feb 11, 2007 | 10:06 AM
Durango_Boy
Good idea. I have a bunch of old speakers and hard drives that I'll be stripping the magnets out of. Sweet.
