Rear spring questions?
Old Feb 14, 2007 | 10:29 AM
MakoShark72's Avatar
MakoShark72
Default Rear spring questions?
I need to replace my rear spring on my 72.
Are the 9-leaf and 7-leaf springs interchangeable?
Benefits of one over the other??
Ride and handling comparison?
Thanks!!!!
Old Feb 14, 2007 | 10:45 AM
early shark's Avatar
early shark
MakoShark72,
I have 2 1971 LS6 coupes, one has standard suspension ( F62 & G32 front and rear springs) the other has F41 suspension.
There is a world of difference between these two spring rates. Both cars sit level, but the F41 front coils and rear leaves are much stiffer in ride.
The standard rear 9 leaf and optional 7 leaf rear spring interchange just fine. However the factory F41 springs have long been discontinued.
Old Feb 14, 2007 | 10:59 AM
rihwoods's Avatar
rihwoods
I got my 7 leaf from Guldstrand Motorsorts...it is about 50# stiffer than stock F41/FE7 GM springs...the ride is great.....put it on my 69 502 with Bilstein Sports...
This spring is 1 1/2" shorter than stock,which allows another 3/4" tire clearance each side...
Rich
Old Feb 14, 2007 | 11:44 AM
sperkins's Avatar
sperkins
Thanks!!!!
I take it that tightening the nuts didn't help?
Old Feb 14, 2007 | 11:49 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
For a normal driver I would recommend the standard nine leaf spring. The F-41 seven leaf spring makes for a much harder ride and not much else.
Old Feb 14, 2007 | 12:00 PM
MakoShark72
Scott, havent tried it yet. The car is "stored" at the local Army base, Ft Lewis, Auto Hobby Shop. Only open Thursday-Sunday. Plan to give it a try tomorrow. BTW, asked the guys at Willcox about adjusting the bolts. They said "only to lower it, not to raise it"....dont shoot the messenger, cuz I dont know. They also said the spring should show noticeable arch with weight on wheels. My spring is pretty flat. But I'll let you know how it works. Will take camera and post pictures this weekend.
MakoShark72
Kinda what I'm thinking...
Old Feb 14, 2007 | 12:15 PM
sperkins's Avatar
sperkins
Yeah that makes sense if the spring is flattened out already. Why not call VB&P? I spoke to Pattie a couple of weeks ago. She was very knowledgeable and helped me pick up the best rear spring for my application. They can custom build peices too if you need something special.
Old Feb 14, 2007 | 12:50 PM
MakoShark72
Will do that this week, thanks.
Old Feb 14, 2007 | 12:53 PM
sperkins's Avatar
sperkins
You can also E-mail her at:
pattie@vbandp.com
Old Feb 14, 2007 | 06:00 PM
ajrothm's Avatar
ajrothm
Why not go to the fiberglass monoleaf? I mean unless you are trying to keep it 100% stock appearing.
I am just curious why to keep the stacked type springs. They're such squeaky bastards.
Old Feb 14, 2007 | 09:21 PM
MakoShark72
Have been checking into monoleaf's..Have heard of failures..and then theres the $$$ factor. But its an option..
Old Feb 14, 2007 | 10:51 PM
ajrothm's Avatar
ajrothm
OH OK, I was just curious as to why to stay with the stock type springs. My car had a TRW 340# monoleaf installed by the original owner back in 1988 along with adjustable struts. The car has had about 40k miles put on since then and I have had no problems with the spring and it actually rides pretty good. Its a TAD stiff but nothing that a corvette shouldn't be. I am also running new KYBs all the way around. I have the receipt for the spring he installed, I want to say it was like $300 or something but hell, that was almost 20 yrs ago. LOL
To Rear spring questions?
