Need an exhaust clamp
Old Feb 14, 2007 | 02:15 PM
CarlR's Avatar
CarlR
Default Need an exhaust clamp
I'm looking for an exhuast clamp for my car. It's the bottom half of the bracket, that's right after the cat. converter. The upper portion (which I have) is held on by two rubber pieces.
The part number is #473039, I believe.
Where should I go to find this piece?
Thanks,
Carl
Old Feb 15, 2007 | 08:06 PM
CarlR's Avatar
CarlR
Wow... No help on this one?
Old Feb 15, 2007 | 08:20 PM
JoeRags's Avatar
JoeRags
Measure the pipe, and go to your local parts store. They have exhaust clamps.
Old Feb 15, 2007 | 09:23 PM
CarlR's Avatar
CarlR
Well the book referred to it as a clamp, but it's not like your usual exhuast clamps. I could get something to work instead, but the car is so stock, I'd rather try to get original parts first.
Thanks for the response
Old Feb 15, 2007 | 11:26 PM
JoeRags's Avatar
JoeRags
How bout a pic? I have no idea what your referring to.
Old Feb 15, 2007 | 11:30 PM
Big2Bird's Avatar
Big2Bird
Does your car have a year?
Old Feb 16, 2007 | 01:54 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
He needs the part on the left. Mid America lists it. Their part no. 603-640 $12.99
Old Feb 16, 2007 | 05:49 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Doc Rebuild probably has it.
Old Feb 16, 2007 | 09:14 PM
CarlR's Avatar
CarlR
Thank You Sir!
I knew this forum wouldn't let me down
Old Feb 17, 2007 | 12:44 AM
KapsSA's Avatar
KapsSA
Just a note...if you have an aftermarket rear Y pipe (i got a stainless one on my white 79) you may need to flatten that clamp in a vise a little to actually get it to clamp the pipe .
Mike
Old Feb 17, 2007 | 12:54 PM
CarlR's Avatar
CarlR
Well a little bit of a setback, they don't have that part in stock, and will no longer be carrying them..
Now that it's known what part I need, are there any other sources?
Thanks!
To Need an exhaust clamp
