Best Way to Remove these?
Old Feb 15, 2007 | 12:17 PM
MorpheusGPR's Avatar
MorpheusGPR
Default Best Way to Remove these?
As I get ready to take the body off I am looking to lighten the load and make it easier for paint later.
I am looking to take both doors off and the front fenders/nose piece.
What is the best method to do this?
I am also looking to remove the steering rack to get that out of the way.
Old Feb 15, 2007 | 01:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: Bodies were painted at St. Louis with the doors and front clip in place. Most folks don't remove the clip for paint. Leave the doors on -- no sense doing work you don't have to do.
Not sure what you meaning by removing the steering rack for paint. You will have to disconnect the steering shaft from the box in order to lift the body off the frame.
Old Feb 15, 2007 | 04:40 PM
MorpheusGPR
Well I am looking to take them off to make it lighter, and I want the door jams to be painted well. I am also going to have to get the rust in the bird cage fixed.
The steering rack is not for paint, but for lifting the body and getting things out of my way. I know the power steering unit leaks so I am thinking about just getting a new one unless a shop can refab this one and clean it up at the same time. (powdercoat?)
Old Feb 15, 2007 | 06:42 PM
chris75stingray's Avatar
chris75stingray
the doors are easy to pull off. just 4 bolts on each side.
Old Feb 16, 2007 | 12:13 PM
MorpheusGPR
Great thanks.
To Best Way to Remove these?
