Costco Engine Stand
Old Feb 15, 2007 | 07:29 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Default Costco Engine Stand
Bought this stand from Costco online. $329 shipped, but it's kind of a POS,however what did I expect for $329 shipped.
http://forums.corvetteforum.com/atta...1&d=1171585491
As you see the frame is held together by the 2 long rods at the bottom and 1 bolt through the wheels, on each end.
Tach, water temp, oil pressure, vacuum gauges, & a key starter switch.
I'll be spending some time on the welder making this a little more sturdy. It's OK for a one off engine, but if you are going to build a few then I would spend a little more for a better stand. The kit comes with a coupling for water hose cooling, but I'm going to add a frame for a radiator.
Old Feb 15, 2007 | 07:53 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
I'm wondering if I can build this one any cheaper.
http://stoutmfg.com/
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
yikes thats alot of dough for something you have to modify
Old Feb 15, 2007 | 07:55 PM
bobs77vet's Avatar
bobs77vet
you can get materials prices from
www.metalsdepot.com
although i think what you do is buy a stand off of Ebay that has the casters etc and then add to it.... i'll look for a stand....
Old Feb 15, 2007 | 07:57 PM
bobs77vet's Avatar
bobs77vet
heres the bottom assembly with casters....you just add to it
http://cgi.ebay.com/ebaymotors/Engin...82027932QQrdZ1
heres another one
http://cgi.ebay.com/ebaymotors/NEW-P...85025091QQrdZ1
Old Feb 15, 2007 | 08:22 PM
JoeRags's Avatar
JoeRags
Send it back... tell them its crap. They will refund you if you push.
Old Feb 15, 2007 | 08:24 PM
ratflinger's Avatar
ratflinger
I'm sure you could, it looks sturdier. I kind of wish I had built one, but this was expedient. Costco would take it back, but I'll just reinforce it & use it.
Old Feb 15, 2007 | 08:26 PM
ratflinger's Avatar
ratflinger
Costco says they'll take it back at any store, they probably would. I'll use this, but thought I'd warn anyone else not to expect much if they order one.
To Costco Engine Stand
