OK, so Durango boy was right....stereo stuff
http://www.woofersetc.com/index.cfm?...roduct_ID=3059
I went to a custom audio shop I have used several times before and let the owner check it out. Here is what he wants to do:
1) 10" Pioneer Premier Sub(pancake style) in a custom box, just to sit on top of the storage compartments, then with a grill over it so the T-tops can rest on it slightly.
2) The a DB component set in some custom made kick panels, angling the speakers towards the driver/passenger. The kick panel will be a pass through type and wrapped in black vinyl to match everything else.
3) A DB amp behind the passenger seat, mounted to the bulk head, its 125w rms X 4 running at 14Volts. He said at 12.5-13.0 volts(like car off) its around 95w rms per channel Use 2 channels for the component sets, then bridge 2 channels for the sub giving it around a true 180-200 watts RMS.
4) Finally use my 4x6" dash speakers as mid-highs as a filler, running off the head unit but using the filter in the HU to cut the lows out. He said all in all, this would be a great combo for the car, nothing to win competitions but a decent street stereo that fits.
Right at $850 installed with tax....does that sound like a decent deal? The kick panels are about $300 of that but he says they are a necessity to get the right air space and pass through for the components.
I am not sure about "DB" stuff, is it any good?
TIA.
BTW I have the car scheduled for tuesday, he says its about 2-3 days worth of work.
That all looks good with one exception. Pancake subs have a VERY low Xmax value. That's total travel of the voice coil as it moves in and out. The Xmax is what makes good bass. A speaker with low Xmax won't produce a lot of bass. It'll be clear and punchy...but nothing that'll shake you.
Also, I am not familiar with the DB brand...what's that short for?
So you think it would be better to NOT go with the pancake then?
They had another sub in there there I was going to ask about but he insisted on building the box. This one was a sony x-xplod in a small wedge type box. It had two metal poles going over the face of the sb to protect them. It seemd to me a truck type box. He had it for $159. The box looked to be about 8" thick or so at its deepest point.
The amp and component set were both DB. I saw the component set and it looked pretty good but... who knows..its probably just junk he gets really good pricing on.
Maybe I should just buy all of my own stuff and let him install it?? I know he will then RAPE me on labor.
I mainly listen to alternative rock and some popular rap and R&B. I am not going to need anything to hit TOO hard although I used to have a JL Audio 10 in a pro wedge box and it did sound pretty damn good.
I know I can get the stuff MUCH cheaper on ebay to maybe offset the cost of labor.
So I could get your component set you listed, and recommendations for an amp? Or should I just buy his amp?
Shafrs, how did you mount the amp to the ceiling? is it mounted on wood or somehow glued to the bottom of the body?
I want to know more about this DB stuff. Find out what you can, maybe a better link. It may be a new company that has good products.
I am really unsure of this sub thing now. I mean this guy is a new owner of this place that I used to use a lot. He seemed like he knew his $hit but was also all about the money..I could tell that.
I think I might feel more comfortable buying my own component set, a JL Audio 10"(which I am sold on) and maybe my own amp. His amp is $189 for 125x4 rms.
I don't want some no name $hit in here.
The site is very shy about technical specs...but from what I can see it's good equipment. The stereo shop guy may be all about the money, but this is a fairly new product by a guy well known in the car audio world.
I would actually be excited to try some of his products if I had a project to work on.
That price you listed, which was a total for everything is not bad at all for custom work and the amount of equipment in the sale.
Without having better knowledge of the specs, and without knowing the installer...I would say it's a safe move to go ahead as he's layed out.
I would love to do this work for you but you're kind of far away.
I saw the amp he was talking about on db drive online but he never gave me part numbers on the stuff so.... I am sure it will be good enough for what I want. I mainly listen to rock anyway and just don't want distortion.
I'm looking around right now for advice on the Pioneer pancake sub. I checked it out on the site but found little customer feedback that didn't look canned. Give me a bit of time and I'll see what I find.
Other than that, it looks like a good system. I did like the look of his amps. Like I said he layed out a pretty good system, and did it a lot like I would have done for a customer of mine with storage constraints.
I'm planning on making small fiberglas boxes that will fit in that unused gap over the rear wheel wells for my rear component set. The sub box will be tiny and just set wherever there is room.
OK...THANKS for all your research bro.... I know you know your stuff! Yeah I think the smal sub in the small inclosure will fit in the rear better and leave me room for T-tops, rear window tray and some bag-a-chairs for the cruises...maybe even a cooler for my beer!
: DISCLAIMER :
Don't drink and cruise....
Keep in mind this is all by someone who's very adept at tuning these kinds of systems so hopefully your stereo shop will be up to the task.
DB thanks for your research, I feel better about the purchase now. $850 is a lot of jack for me, especially considering the other $180 I had already spend in HU and speakers.
Back when I did some competing, I spent $2500 on the stereo system I installed in my Durango. I did the work myself, and bought all the gear. It's all since been replaced with more practical gear, but what you're paying is a good price for the system you'll get.
well there has been a slight change in plan. I called the guy today to see if I could bring car in today as opposed to tuesday because of inclimate weather. He couldn't work with me nor did he seem to even care. I kind of got a bad feeling about him the first day I met him, he seems like he is all out for himself and making loot. SOOO with all that being said, I think I will wait and maybe go another route. I wanted a good sound but I wasn't all that crazy about having big speakers and tweets hanging out of my kick panels. Plus I REALLY did not need to spend another $800-900 on stereo stuff...I have some paint work I need to get done and I think the money would be better spent on that.
I am thinking maybe I will just get some 6x9s, stick em in a box, mount the amp on the box and wire it up myself. Run my 4x6s in the dash off of the HU but pull all of the bass out of them, maybe use the HPF in the HU on them. Let the amp drive the 6x9s. Then I can take them out whenever I want. I figure I could do all of this for around $300 or so. I really like the 6x9 box that corvette central sells for a C3 but its like $200 itself. I am gonna shop around at some sites and see what I can find.
