alignment
Old Feb 18, 2007 | 10:00 PM
car kid's Avatar
car kid
Default alignment
hi eveybody
I have a 69 t-top
I'm wondering if I need to have the body on the chassis to do the alignment on the rear wheels. And what's the easiest way to do that.??
how can I know what year is my motor??
Thankyou very much for your help
carkid
Old Feb 18, 2007 | 10:18 PM
Big2Bird's Avatar
Big2Bird
Can you tell us more?
Old Feb 19, 2007 | 12:01 AM
TimAT's Avatar
TimAT
A profile would be good.
Old Feb 19, 2007 | 10:44 PM
car kid's Avatar
car kid
tell me what you need to now ans I will tell you
I realy need your help thank you?
Old Feb 20, 2007 | 09:06 AM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
You can get close with the body off if you undo the spring and set the cat at what you think will be the ride height.
Just use a tape measure and set the wheels straight ahead and straight up and down. Not ideal for driving but good enough for test drives and driving to get it aligned.
For the Engine there are number cast into the block above the bell housing and some stamped into a pad on the passenger side front part of which should match the VIN of the body. You can decode the stamped number to learn more about the car.
For the cast in number googl for chevy block casting numbers, there is a site around that tells you lots about what the block is.
Old Feb 20, 2007 | 12:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'd do it with the body on and everything installed. Some auto manufacturers even specify putting weights in the seats when doing an alignment so the car is sitting in as close to its driving condition as possible.
Old Feb 20, 2007 | 01:32 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by car kid
...I'm wondering if I need to have the body on the chassis to do the alignment on the rear wheels...
how can I know what year is my motor??...
You could probably set the toe without the body, but that's only half the story. You would need the weight of the body to get the camber to the point where you could get the car to an alignment shop.
Jot down the numbers on the engine pad at the front of the right head.
Old Feb 21, 2007 | 12:51 AM
car kid's Avatar
car kid
are the shims the only adjustment or is there other poin to get it right
Old Feb 21, 2007 | 12:57 AM
car kid's Avatar
car kid
the numbers of the motor are 152101455 T0830070
can some one tell me the year of the motor I know that it's not the one that came with the car. thaks for your help
To alignment
