All my T10 parts are here and getting ready to do the swap. My question is, how will the car run after the swap without changing the rear end gears? Should I wait and do all at the same time (tranny and gears)? What are the pros and cons of going with 3.54 gears?
If you swap the tranny before you change the rear gears, you'll be able to get any bugs worked out KNOWING that they'refrom the tranny swap. If you change both at the same time, if there are any bugs is anything, you'll have to dig around for the source. I'ddo one at a time, unless you're 100% sure there are no little hidden secrets in anything..
I just wanted to know performance-wise how the car will feel considering the swap to a 4 speed but still using the stock 81 automatic rear end gears. If it's going to be sluggish, might as well change the rear end too after all the work of swapping the tranny. What are your opinions?
Originial '81 rear gears with an auto. trans was 2.87. Won't work very well with a 4 speed, IMO. You will need at the very least 3.36's, preferably 3.55's.
For highway use stock gears would work. For stop light to stop light, you will be dissapointed. Will require considerable cluch slipping on a hard leave to keep it from bogging down.
So, I guess I definitely have to change gears considering Los Angeles traffic and some lights that are only a block apart. Thanks for the advice.
