Speaker and amp suggestions?
Old Feb 23, 2007 | 04:00 PM
DeeVeeEight's Avatar
DeeVeeEight
Default Speaker and amp suggestions?
I have a newer Sony Explod head unit with an Ipod adapter, a Dual 600 watt amplifier and 10" speakers rated at 600 watts in the box shown below. I also have the small speakers in the dash (pioneer). My problem is I can't hear the bass over the flowmaster dual exhaust when traveling at speed.
Any suggetsions?
Old Feb 23, 2007 | 05:04 PM
Durango_Boy's Avatar
Durango_Boy
First of all...you don't really hear bass, you feel it. The only thing you should hear is the music performed by your front or rear stage. The highs and mids will be what you listen to. You can get low frequencies from your subs and you hear those, but the bass you speak of...that thump, is felt more than it's heard.
The way we feel that bass, is by proper imaging. The subs the way you have them are not going to be very effective. Turn the box around or aim it so there is a surface in front of the cones. The sound waves bouncing off of a surface will increase what you feel and or hear.
Also, the subs look cheap and probably have a low Xmax value.
Old Feb 23, 2007 | 05:36 PM
Big2Bird's Avatar
Big2Bird
Change mufflers.
Insulate the cabin.
Get a hearing test.
Old Feb 23, 2007 | 05:54 PM
JoeRags's Avatar
JoeRags
Sonopex? I've heard of some pretty bad brands, but never even heard of that one... What kind of amp you running?
Old Feb 23, 2007 | 06:39 PM
Durango_Boy
It's a shame all that stuff is paid for. The amp looks like a Pyle or Legacy or Pyrimid, and if it says 600 W then it's probably closer to 150 RMS.
I'm not ragging on anyone for their equipment, but it's clear why you cannot hear or feel what you want to hear and feel.
Old Feb 23, 2007 | 06:44 PM
Big2Bird's Avatar
Big2Bird
What does RMS stand for?
Old Feb 23, 2007 | 06:46 PM
SIXFOOTER's Avatar
SIXFOOTER
yea ya really need to know what your buying in that business. For years I kept an amp laying around that advertised as a 100 wattx2 PIP
It was about 6" square and 3/4" thick. Would not have even been big enough for a heat sink on a 50 watt amp.
I figured the PIP meant Peak Imaginary Power
Old Feb 23, 2007 | 06:47 PM
SIXFOOTER's Avatar
SIXFOOTER
Root Mean Square
think od a sine wave and the voltage you measure, its not the peaks but the "RMS" value
Old Feb 23, 2007 | 06:50 PM
SIXFOOTER's Avatar
SIXFOOTER
http://en.wikipedia.org/wiki/Root_mean_square
Old Feb 23, 2007 | 06:56 PM
Durango_Boy
Honest Power Ratings:
The most honest way to rate a speaker is to give the rating as continuous RMS watts (ex: 150 watts continuous RMS power). You may hear speakers advertised as "150 watt 6 x 9s" or "100 watt 6 x 9s" and you may instantly think that the "150 watt 6 x 9s" are better and will play louder than the speakers rated at 100 watts. The first thing you should realize is that speaker ratings are OFTEN exaggerated. Then you should ask if the rating is in RMS or peak watts and are the speaker ratings for instantaneous or continuous power. Most car audio speakers (with the exception of some subwoofers) are rated in peak power or music power. Only a few speakers (generally the higher quality speakers) are rated in RMS watts. While peak power is a legitimate way to rate speakers (as long as the manufacturer tells you that the power rating is in peak watts), it can be deceptive.
Peak vs RMS:
You know that peak power is 2 times the RMS power. If a speaker is actually capable of handling 150 watts of peak power it would only be rated to handle 75 watts RMS. If a speaker is rated to handle 150 watts 'music power', it may mean that the speaker will take only very short bursts of power approaching 150 watts RMS. Even if there are two speakers from different manufacturers which have the same power ratings, one of the manufacturers may be more conservative in their ratings than the other manufacturer. The more conservatively rated speaker would be more likely to handle its rated power. Bottom line, beware of power ratings on speakers. Knowing that some manufacturers are less than honest in their power ratings, will likely help you to make better decisions when buying speakers.
Amplifiers and Speakers:
Many people ask the question... Can my speakers handle this amplifier or will this amplifier blow my speakers. Well, the truth is that any speaker can be driven by any amplifier. The only time that there will be a problem is when the person operating the system becomes abusive. Most people (and I do mean most) drive their amplifiers well into clipping. I know what your thinking... I never drive my amp into clipping. Well, you must be one of the very few. Generally speaking, if you have friends who are impressed by high volume, you drive your system into clipping.
Old Feb 23, 2007 | 07:02 PM
Big2Bird's Avatar
Big2Bird
What is clipping?
Old Feb 23, 2007 | 07:08 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Peak vs RMS:
You know that peak power is 2 times the RMS power..
Wrong again,
peak is the square root of 2 times RMS
1.414
Old Feb 23, 2007 | 07:23 PM
PeteZ's Avatar
PeteZ
What is clipping?
Clipping equals audio distortion of the media being listened to. The media is not faithfully reproduced as it was originally recorded. Clipping occurs when the final output stage in the power amplifier is overdriven by turning the volume control way too high.
Pete .
Old Feb 23, 2007 | 07:27 PM
DeeVeeEight
I was thinking of flipping the box so the speakers pointed up, towards the window... so that may help, huh?
And yes - I do not deny it. It IS a cheap set of speakers. I paid $60.00 at Pep Boys for the box with the speakers. I liked the fact that they fit in the rear cargo area without any modifications. They sound surprisingly good for the money as long as they are not competing with the exhaust system. The amp is made by DUAL and as I stated earlier, is mated to a Sony head unit. I have felt the hair on my head and arms move at certain low frequencies with these speakers, so they can deliver some....
Old Feb 23, 2007 | 07:29 PM
onaqwst's Avatar
onaqwst
turn the box around
Old Feb 23, 2007 | 07:34 PM
Big2Bird's Avatar
Big2Bird
Pete .
I would imagine that would cause a great deal of harmonic distortian.
Old Feb 23, 2007 | 09:07 PM
PeteZ's Avatar
PeteZ
Here a few other considerations to think about when selecting speaker's for a Corvette audio playback system:
1. 6" x 9" speakers will faithfully replicate frequencies within the 2kHz to 8kHz range ... this range varies depending upon the speaker cone material composition.
2. 'Tweeter's' reproduce audio frequencies at the upper levels of the human hearing range which may be on the order of 7kHz up to 20kHz.
3. 'Woofer's' reproduce frequencies at the lower end of the human hearing range ... down around 30Hz up to 3kHz.
Remember that the human hearing range is measured to be between 20Hz and 20KHz. Also remember that we humans 'hear' frequencies at different amplitudes across the range of 20Hz to 20kHz.
What the heck does this mean? Well, we 'hear' frequencies or sounds on a non-linear scale.
To illustrate, imagine for a moment a sad face icon, just the opposite of this happy face , look at the curve of the mouth on the sad face ... both ends are turned down with respect to the middle portion.
Okay, you got it, that curve approximates the curve we humans have in hearing sound. At lower frequencies (the left-side of the down-turned mouth), our hearing is diminished. During mid-range frequencies (the middle of the mouth) we hear much better, and at higher frequencies (the right-side of the mouth), the sound amplitude we hear becomes diminished again.
Well, sheesh! How do we compensate our hearing to clearly hear all the sounds at the same level or volume we wish to in an audio playback system??
Glad you asked! The answer is to boost the amplitude of the frequencies at the lower and upper ends of our hearing spectrum.
Well, how is that accomplished?? By separating the human hearing range into individual frequency components.
Granted, most music when recorded is already compensated to boost low and upper frequencies through the use of RIAA equalization techniques. This is good, but not sufficient to overcome all the various noise sources in our old 'Vettes.
The lower and upper frequency sounds must be further boosted again. This is where an audio equalizer will help restore the full frequency range to meet your individual hearing requirements.
If one is looking to get a bass boost to 'feel' those low frequencies, then one must obtain a 'woofer' that is capable of producing those low frequencies without distortion. Specifically look for a speaker with performance specs that allow the speaker cone to travel in excess of an inch or more.
Why?? Simply because the speaker must get a large volume (bolus) of air moving so that same impacts upon on our body ... we do not hear this mass of air ... we only feel it.
So, I'm 'gabbing' a lot here ... sorry for the long post.
Hope this helps ... if more questions follow, let me know.
Best Regards,
Pete
Old Feb 23, 2007 | 09:14 PM
PeteZ's Avatar
PeteZ
Hey Jeff,
Most certainly there would be harmonic distortion of all frequency components plus the derivative frequency.
Good point.
Pete .
To Speaker and amp suggestions?
