Ball joint question
Old Feb 25, 2007 | 03:40 PM
saudivette's Avatar
saudivette
Default Ball joint question
I went to install my new ball joints tonight and had a couple of problems.
Problem 1: How did the rubber boot stay on as there was nothing in the kit that would do that? I finally twigged that I might need something off the old ball joint which, luckily, I kept. I rumaged around and came up with a rusty piece of metal that goes inside the control arm and lines up with the ball joint mounting holes. Problem 1 solved, just gotta clean the said piece up now.
Problem 2: There's a hole in the "back" of the ball joint but it's not threaded so how do I get the grease nipple in there? Again, I looked at the old ball joint and the part that the grease nipple screws into is attached to the ball joint somehow (too much grease to see if it's rivets or spot welded). Do I need to get this bit off the old ball joint somehow?
Any ideas?
Old Feb 25, 2007 | 04:21 PM
Durango_Boy's Avatar
Durango_Boy
#2 - The zirk will self tap into the hole. Just apply pressure with a finger while tightening it with a wrench. It'll catch, and then thread it down flush. Don't over-tighten and strip it. Then you'll have problems.
Old Feb 25, 2007 | 04:24 PM
saudivette's Avatar
saudivette
But that part of the bll joint is quite thick steel, not sheet metal
Old Feb 25, 2007 | 04:43 PM
Durango_Boy
In that I'm unfamiliar with it. Sorry.
Old Feb 25, 2007 | 04:54 PM
thrilher's Avatar
thrilher
sounds to me like you may have non greasable ball joints..is the hole directly opposite of the of the threaded spindle or on the side of the ball? your desciption makes me think you see your hole on the side of the ball itself. i've seen you in the forum alot and i'm sure i am misunderstanding but if its not threaded its not right, the grease zert is a fairly soft metal and it won't cut threads very well.i have them break off on occasion if i try and pull my grease gun off under pressure. if it is the zerk hole then maybe it wasn't tapped at factory. Mine were tapped.
your rubber will be held in position by the adjoining piece when bolted and torqued.it doesn't need to be seated or sealed to hold pressure at all. it is a dust cover and water repellant more than anything, the grease in it serves no purpose but to keep moisture and in your case sand out. its the fresh grease between the ball and socket that carries the load.
Old Feb 25, 2007 | 05:22 PM
saudivette's Avatar
saudivette
Originally Posted by thrilher
sounds to me like you may have non greasable ball joints..is the hole directly opposite of the of the threaded spindle or on the side of the ball? your desciption makes me think you see your hole on the side of the ball itself...
if it is the zerk hole then maybe it wasn't tapped at factory...
The steel at the bottom (top?) of the ball joint where that little hole is, is about 2-3mm thick. There's no way the grease nipple will cut it's own thread through it.
Where the grease nipple screws into the old ball joint is like a "top hat" shape and isn't on this ball joint. There was nothing else in the kit and I can't remove the bit off the old ball joint - it seems to be either spot welded or riveted on. It's still covered in 25 years of crap though, so I can't be sure
Old Feb 25, 2007 | 05:24 PM
Durango_Boy
Some zirks are designed to be 'tapped' in with a small hammer.
Old Feb 25, 2007 | 05:36 PM
stingraymaniac's Avatar
stingraymaniac
Its self tapping just wrench it down
Old Feb 25, 2007 | 06:13 PM
roger55's Avatar
roger55
yup
Old Feb 25, 2007 | 06:17 PM
Durango_Boy
That's what I said too until I came to think the metal was too thick. Looking at it again, they look just like the ones I screwed mine into.
Old Feb 25, 2007 | 09:05 PM
thrilher's Avatar
thrilher
that balljoint looks much different from mine but yes that doesn't look like tempered steel. and to think of it my zerks broke on the narrow neck not at the threads anyway. good luck!
Old Feb 25, 2007 | 09:11 PM
Topless75's Avatar
Topless75
I pushed a zerk fitting into mine. The "push-in" zerks have raised rings/ridges around 'em where the threads normally would be.
JustForFun's Avatar
JustForFun
just screw it in...it will go
Old Feb 25, 2007 | 09:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Crank it in...just not too tight!
Order a set of the Energy Suspension poly boots and throw the rubber junk away. The poly boots just sort of stick in place.
Old Feb 26, 2007 | 09:22 AM
Wuttin's Avatar
Wuttin
just did it yesterday on ball joints and tie rod ends...start slow with a little finger pressure then seat it flush. No issues.
Old Feb 26, 2007 | 09:24 AM
Durango_Boy
Let us know how it goes Saudi. If you strip that zirk I'll send you some spare ones.
Old Feb 26, 2007 | 11:10 AM
noonie's Avatar
noonie
saudivette
First check to see if the hole is sized the for a #7 drill bit or close. Don't have the xover chart handy.
In past years, ball joints came threaded traditionally with 1/4-28 holes and plugs installed. They are saving money these days by not installing the thread or threaded hex head plugs.
The best method is to put grease on a 1/4-28 tap and run it in 3 or 4 turns and use a grease zerk that has a 1/4-28 tapered thread. The ghrease will trap the cuttings. It can tighten without bottoming out because of the tapered thread even though it isn't a true pipe thread.
Here is a chart of different types and sizes of grease zerks but most automotive people will only be familiar with the more common one I previously mentioned.
To Ball joint question
Old Feb 27, 2007 | 05:44 AM
saudivette's Avatar
saudivette
Thanks for all the input guys. I tried just screwing the grease nipple in and it worked! I was convinced that it would never cut it's own thread through the steel of the ball joint. You learn something new every day!
Thanks again, beers on me
Old Feb 27, 2007 | 10:23 AM
Durango_Boy
Sweet, Fosters.
Old Feb 27, 2007 | 03:24 PM
saudivette's Avatar
saudivette
Originally Posted by Durango_boy
Sweet, Fosters.
FOSTERS????
