18" wheel ?
Old Feb 25, 2007 | 04:00 PM
garay77n84's Avatar
garay77n84
Default 18" wheel ?
i have a friend that has custom wheels on his camaro z28 18x8.5 with o offset and 4" backspace, would these wheels fit? i am about 2 hours from him, and i would hate to make the drive with me working alot,my concern is the hub in the middle? thanks wheels will be going on my 77 vette.
Old Feb 25, 2007 | 04:26 PM
80vettefan's Avatar
80vettefan
i have a 93Z-28. in my research i've discovered that you can use the front wheels from a late corvette all the way around a camaro. so, i would think you would need the spacers like if your where putting on late corvette wheels. the bolt pattern will be the same.
Old Feb 25, 2007 | 04:34 PM
lvrpool32's Avatar
lvrpool32
The measurements you give above mean that they will fit , but stick out .5" more than stock.(Stock wheel will be 8" wide with 4" backspace)
The only thing to remember is the shape of the wheel, a stock 'vette brake caliper is slightly proud of th ebrake mounting face...so the shape of the wheel's spokes need to be considered. Do you know the make/model of wheel?
Nick
Old Feb 25, 2007 | 05:33 PM
wnjlt1's Avatar
wnjlt1
the numbers garay77n84 has given are a little off
18x8.5"
0 offset
4" backspace
on a 8.5" wide wheel and 0 offset, the backspacing would be 4.75" and not 4" bs. with a 4" bs it would be a -19 offset. you may want to trail fit them before you purchase.
Old Feb 25, 2007 | 11:00 PM
garay77n84's Avatar
garay77n84
Nick
i picked up the wheels awhile ago,they are panther 18x8.5 with 4.75 backspace and believe it or not i tried the front wheel and it fit perfect,
i will post pics tomorrow i have to buy tuner lugnuts. thanks guys.
To 18" wheel ?
