bad firewall
Old Feb 26, 2007 | 11:15 AM
pushin_400's Avatar
pushin_400
Default bad firewall
also my firewall is rotted and it needs replacing as well as the pilars on each side of the car that support my windshield and roof. what should i look out for and how should i go about doing this??
any advice is greatly appreciated...
thanks
Old Feb 26, 2007 | 02:09 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "rotted"? Fiberglass doesn't rot. Got a good Corvette salvage yard in your area?
Old Feb 26, 2007 | 03:21 PM
pushin_400's Avatar
pushin_400
rotted where the pilars are bonded to the firewall (just under dash)
Old Feb 26, 2007 | 03:53 PM
SIXFOOTER's Avatar
SIXFOOTER
you talkin about the windshield frame corners, #2 mount pockets and the like? or more than that?
Old Feb 26, 2007 | 04:46 PM
pushin_400's Avatar
pushin_400
yeh like that
Old Feb 26, 2007 | 10:15 PM
chris75stingray's Avatar
chris75stingray
thats a pretty big job. you'll have to remove the doors ,front clip, etc to get at that stuff.
Old Feb 26, 2007 | 10:18 PM
SIXFOOTER's Avatar
SIXFOOTER
You may be able to fix it, I have the same problem on mine and am in the process of repairs. Fabbing a repair section for the #2 mount is not too difficult,, basically a rectangular piect of sheet metal with tabs on all 4 sides. The upper, sides and upper corners for the WS frame are redily available on line. Caladonia, zip, several others have them. I used repair sections for the rocker channels from Caladonis for the rocker chanel repairs. Takes some work, but it can be done. In the process I am re learinig to weld.
To bad firewall
