need HELP. smoking under the dash
Old Feb 26, 2007 | 08:56 PM
80vettefan's Avatar
80vettefan
Default need HELP. smoking under the dash
started the car to warm up. hasn't been started in about 3 days. went back out to leave and theres smoke comming from under the dash. that o so familiar aroma of burning plastic wiring sheath in the air.
it only does it when the engine is running. with the key, fan motor, radio and lights, nothing. couldn't pin point a location. is there something to look for first? something common? or do i just start sorting through wires?
the car is an 80.
Old Feb 26, 2007 | 09:21 PM
VettePower's Avatar
VettePower
Does the smoke continue? Or have you blown a fuse, like it should??
Old Feb 26, 2007 | 09:38 PM
Big2Bird's Avatar
Big2Bird
Man. As a sparky. I am compelled to say you have to find that source/cause. It could be anything. I had a friend's Porche burn up the whole inside like that. Pull the battery cable NOW!
Old Feb 26, 2007 | 09:39 PM
wills670's Avatar
wills670
Disconnect the batt. first. You do not want to catch something on fire and then start looking. It should have blown a fuse or a fuse link.
If it has shorted a wire it should be fairly easy to trace.
But be sure to disconnect the batt. before you have a fire.
Old Feb 26, 2007 | 10:26 PM
80vettefan's Avatar
80vettefan
the smoke continues. gets thicker and thicker. sorry, should have told you that i pulled the + cable.
Old Feb 26, 2007 | 10:39 PM
Big2Bird's Avatar
Big2Bird
You gotta find it. I wish I had pics of that Carrera that smoldered itself out over a week. $15,000 ins repair bill, then he sold it.
Old Feb 26, 2007 | 10:49 PM
Bangkok Dean's Avatar
Bangkok Dean
The surgeon general has determined that smoking is bad for your Vette
Old Feb 26, 2007 | 11:01 PM
SIXFOOTER's Avatar
SIXFOOTER
Bite the bullet and pull the center console apart and see where it is. You can't let out much of the magic smoke without leaving marks somewhere. Better to do it now instead of fartin around and your next post shows a burned out husk
Old Feb 26, 2007 | 11:15 PM
80vettefan's Avatar
80vettefan
agreed, it won't be driven again until i find something. why the center console? the smoke is under the dash. is there something under the console i should look for?
Old Feb 27, 2007 | 12:08 AM
SIXFOOTER's Avatar
SIXFOOTER
lots of stuff terminates there, your also going to want to pull the drivers dash out
Old Feb 27, 2007 | 12:16 AM
Big2Bird's Avatar
Big2Bird
I would start with anything modded,
I.E. Aftermarket stereo, splices that are not factory, TAPED spots, anything Bubba.
Old Feb 27, 2007 | 01:00 AM
SEVNT6's Avatar
SEVNT6
I had this happen. Smoke from the center console. From a rear speaker wire, modded, from a taped spice done by Bubba. And for this kind of workmenship I paid almost $400 for the first Alpine cassette player back around '78-'79. Still have it in the car. I think it puts out 8 watts. Amazing what you can get now for the money ain't it?
To need HELP. smoking under the dash
