Cooper tires?
Old Feb 28, 2007 | 02:05 PM
Carl Granquist's Avatar
Carl Granquist
Default Cooper tires?
I need to replace my bias ply F70 Firestones and not sure I want to wait for BFGoodrich thru TireRack. Could I hear from anyone using Cooper Cobras? Good or bad, doesn't matter since I don't know and have never had a set of Cooper tires. Size would be 255/60/15. Got a local bid of about $450 installed/balanced, etc.
Old Feb 28, 2007 | 02:08 PM
Twin_Turbo's Avatar
Twin_Turbo
BfG.................. pretty sucky
General............. more sucky
Cooper cobras.... dangerous tires, no traction in the dry and in the wet your car will be a suicide plane
Old Feb 28, 2007 | 02:17 PM
Carl Granquist
Thanks. I just now see WESCH asked a similar question and is getting a variety of opinions.
I've got to make the change, but just not sure which to go with.
Not a lot of choices in 15" performance, I'm finding.
Old Feb 28, 2007 | 02:45 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Firestone Firehawk Indy 500.
Old Feb 28, 2007 | 03:19 PM
ESU's Avatar
ESU
Yokohama 255/60 on my 79 and luv em. Check out tirerack and see the reviews. About 65 a tire is what I paid.
ESU
Just checked tirerack, 70 bux a tire, cheaper than all the above with better ratings than all the above if you can live with japanese tires on american iron.
Old Feb 28, 2007 | 03:28 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Feb 28, 2007 | 03:38 PM
JungleCat's Avatar
JungleCat
St. Jude Donor '05 thru '26
That price sounds high to me. I was able to get my Coopers from a local dealer for $77 each. After installation, balance, and tax, the price came to $335.40. This was for the 255/60/15s.
Old Feb 28, 2007 | 03:44 PM
gbak's Avatar
gbak
Don't you know any "not sucky" tire?
Old Feb 28, 2007 | 05:32 PM
thrilher's Avatar
thrilher
have had two firestones fly apart and ruin my trucks. it takes an act of congress to make them pay including mailing them the tire at your expense and they decide who's liable. never got my truck repaired. you can pull a '57 out of the weeds with original tires and it'll roll but you can't ride on a tire made in 2000. As a nation were focused on safety, unless it interferes with corporate profits..
Old Feb 28, 2007 | 09:10 PM
jlaw68's Avatar
jlaw68
i was in the same boat about 2 years ago. tore up the whole side of my stepside bed and firestone wouldnt do anything about it, i have pictures, sent the time back and wrote letters numerous time and i got nodda from them. i will NEVER buy another tire from firestone or bridgestone.
Old Feb 28, 2007 | 09:14 PM
3rd_Vette's Avatar
3rd_Vette
Ive got a set of Coopers on my 80
They grip very well and Ive had NO problems.
Old Feb 28, 2007 | 09:28 PM
markdtn's Avatar
markdtn
Bridgestone and Firestone are run somewhat separately, just as Michelin and Uniroyal are. You may get a Uniroyal tire made in a Michelin plant, but never a Michelin tire in a Uniroyal plant. I believe BS/FS are similar.
As far as Cooper Cobra, I have 255/70/15s on my Suburban. I would not consider them a performance tire.
Old Feb 28, 2007 | 09:53 PM
tigers123's Avatar
tigers123
Default cooper cobras
Not a speed rated tire. One hundred fifteen at the most. So if you are not playing bury the speedometer you will get along with them alright. If you think they are an all weather drive in the toughest ran at 70 mph you probably had better look elsewhere as well. But I get along with them just fine. Run 35 psi in them on hot pavement as they are extremely wide tread. Out on the old Kansas plains when it is 100 degrees out, the highway can be 140 degrees hot from heat soak. So if you want to play it safe air them up cold.:o
Old Feb 28, 2007 | 11:36 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Firestone fixed the car tire problem with the Firehawk 500 recall in the mid-70s. The truck tire problem was unrelated, but nearly as old.
Old Feb 28, 2007 | 11:43 PM
SEVNT6's Avatar
SEVNT6
Mine came with the infamous Firestone 500s. One had a tread seperation, 2 went egg shape. Firestones are great for boat docks though...........
Old Feb 28, 2007 | 11:55 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Not sucky tire = not mounted on 15" rim.
I bought my car with the BFG's on it. I thought the tires were just old and the rubber had hardened. It's starting to seem like they just suck. Wish I had started saving for my 17" wheels earlier.
Old Mar 1, 2007 | 12:13 AM
SEVNT6's Avatar
SEVNT6
I put a new set of BFGs on a couple years ago and it's a love/hate thing for me. Problem is when it comes to 15" tires anymore there just ain't nothing worth a crap out there, performance wise. Plus there's fewer sizes now to pick from then ever........
To Cooper tires?
Old Mar 1, 2007 | 07:41 AM
Twin_Turbo's Avatar
Twin_Turbo
the only acceptable to good tire for 15" is the pirelli scorpion zero but it''s an ugly tire w/ that yellow scorpion and the rather high side wall.
Old Mar 1, 2007 | 08:11 AM
panic's Avatar
panic
cooper cobras are honest tires for a 'passenger' car and they last forever, to pretend more from them could mean ask for trouble...
Old Mar 1, 2007 | 10:24 AM
gbak's Avatar
gbak
Isn't there any tire that can be used on the street that have good grip?
BTW I have 16" rims, I have only found BfG and Cooper that are wider than 255/50.
