Clunk is gone !!!
Old Mar 1, 2007 | 01:36 AM
rihwoods's Avatar
rihwoods
Default Clunk is gone !!!
In another thread,I mentioned a clunk sound from my front end in the 78 SA...
This is the condition of original front end bushings(upper/lower control arms,etc) after 29 years.......
After all new bushings,Idler arm etc...it is like driving a new vette...!!!
Rich
Old Mar 1, 2007 | 01:38 AM
Big2Bird's Avatar
Big2Bird
So did you try the poly, or stay with rubber?
Old Mar 1, 2007 | 01:49 AM
rihwoods's Avatar
rihwoods
I used rubber....to many issues with poly...particularly in upper control arm bushings....no kidding...!!!!
Rich
Old Mar 1, 2007 | 08:09 AM
theandies's Avatar
theandies
You had the same clunck I did. I also went back with rubber. I figured it was good for 25+ years It will be good enough for me.
Old Mar 1, 2007 | 08:58 AM
GD70's Avatar
GD70
Rich
What issues?
Old Mar 1, 2007 | 09:15 AM
Muddywaters's Avatar
Muddywaters
Yup...looks just like mine...(All of them). I replaced with poly...no squeaks and feels mighty tight. I did buy a large tube of white grease! Muddy
Old Mar 1, 2007 | 09:22 AM
SIXFOOTER's Avatar
SIXFOOTER
Amazing what a difference it makes huh?
Old Mar 1, 2007 | 09:24 AM
Bangkok Dean's Avatar
Bangkok Dean
Rich, how long did it take you to change everything?
Old Mar 1, 2007 | 10:46 AM
1Z87L8's Avatar
1Z87L8
Old Mar 1, 2007 | 10:56 AM
rihwoods's Avatar
rihwoods
Originally Posted by GD70
What issues?
Occasionally,upper A-Arm bolts can get loose with poly's...not everyone experiences this,but it happens...
Rich
Old Mar 1, 2007 | 11:08 AM
rihwoods's Avatar
rihwoods
It was done at friends shop....labor was 5 hours...
But...I help sell Corvettes for this guy in trade for work on the my vette's...so the tough stuff goes to him...
Rich
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Rich
Loctite is amazing stuff.
Old Mar 1, 2007 | 11:25 AM
rihwoods's Avatar
rihwoods
May work...I don't know....on my rubber ones,I'm going to re-torque after bushings take a set...
Old Mar 1, 2007 | 12:15 PM
swtato's Avatar
swtato
St. Jude Donor '05
I did the same to my Pace Car this fall and it is like a new car! I agree if ruber will last another 25 years that is good with me plus it already rides hard enough and has enough squeaks and rattles!
Old Mar 1, 2007 | 12:33 PM
rihwoods's Avatar
rihwoods
Got one squeak left...T-tops....
Old Mar 1, 2007 | 12:55 PM
Big2Bird's Avatar
Big2Bird
Baby powder.
Old Mar 1, 2007 | 04:54 PM
rihwoods's Avatar
rihwoods
Highly recomended.. Unreal the change....got trailing arms/strut rods done a few months ago....now both ends are working together...
Rich
To Clunk is gone !!!
Old Mar 1, 2007 | 05:17 PM
SEVNT6's Avatar
SEVNT6
I had one pop out last fall on my upper left and I'm going rubber. If this one lasts 30 years that would make me 80 years old.........
Old Mar 1, 2007 | 05:31 PM
vetteaddic's Avatar
vetteaddic
Rich
This happened to me the other day,it was the lowers,bolt fell out and the shaft moved about an inch or I mean the a/arm moved,just got done doing a blast down the hiway and heard bolts and washers as I got off the hiway,soo I guess loctite is a good idea when running poly,
It's the first I heard of it.
Old Mar 1, 2007 | 08:46 PM
rihwoods's Avatar
rihwoods
Here is what I've learned...just hitting small bumps can work bolt loose...(not in every case). The poly is not as forgiving as rubber...I've personally seen two vettes where this has happened,and both were drivers side forward bolts...one of the vettes incurred damage to power steering system and was a real mess...
I'm not against poly's per se...but I'll never use them on control arms...
Rich
