Alternator Voltage : 17+ Volts?
Old Mar 1, 2007 | 07:52 AM
GPD's Avatar
GPD
Default Alternator Voltage : 17+ Volts?
My alternator is putting out @17.3 volts. I've had a battery burn up on me. I am assuming the alternator is bad. Any other reasons that could cause this?
Old Mar 1, 2007 | 08:14 AM
Tommy Samuels's Avatar
Tommy Samuels
You've got a stuck voltage regulator in the alternator. If it's the original piece for your car and you care about matching numbers, you can get it rebuilt. Or it's an inexpensive part at NAPA< Advance, etc..
Old Mar 1, 2007 | 12:03 PM
coolerthanethan's Avatar
coolerthanethan
i burned up a few MSD 6al because of the same problem, except my alt voltage regulator would only pull 17-18 volts under hard load and never at idle. made it very hard to diagnose. new alternator fixed it all. just buy a nice new alt.
Old Mar 1, 2007 | 12:37 PM
Big2Bird's Avatar
Big2Bird
Nope. I am willing to bet you might have damaged more than just the battery.
Old Mar 1, 2007 | 02:12 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
stuck / bad regulator should not exceed 14v area
Old Mar 1, 2007 | 03:33 PM
Ironcross's Avatar
Ironcross
Since I dont know what year the Vette is, There are two alternator regulator systems on Vettes from 68-82. Those with a external regulator and those with internal regulators. Which ever one you have the symptoms are the same. Increased voltage means the regulator is not working and the alternator is blasting full force. Continued excessive voltage will also damage the whole electrical and lighting system plus blow out all the bulbs. 72 and earlied is external, from 73 on, it`s internal
To Alternator Voltage : 17+ Volts?
