I had a set on a smallblock Vette in the early 90s...they were a good fitting quality header with what I thought was a very durable coating, never any rust issues. They were also one of the lowest priced headers on the market.
Ditto on that. Got mine Jet-Hot coated & they're still in excellent condition & for sale if you're interested. Had to get different headers because of engine change with different exhaust port location.
I've still got a set of those. Bought them around 1984. I was going to replace them but I found that Hookers won't fit with my angle plug heads. The old Blackjacks fit like a glove! They don't look so good anymore - the aluminum coating is discolored. But there is no rust at all. I was thinking I might send them out to Jet Hot and get them ceramic coated.
There is one issue with them though. They have a 4 bolt flange on the collector which doesn't seem to exist anymore. You would have to do some fabricating to hook up an exhaust. Either make a 4 bolt flange for the tailpipe side or cut the collector off the header and weld a new one on.
Blackjacks on MY 79 L82. Put these on 22 years ago, still in great shape(very low mileage, tho). Excellent fit and makes spark plug changing a 15 minute job!
That sounds strange. Mine are 3 bolt. Got them 1989, I think.
I also bought a set back around 1983-84? About $90 then. stored them until 4 years ago and installed them. They fit great and only show rust where I nicked the coating off. Installed them on my 72 last summer and broke in a cam, so they were glowing orange for a while. Still have them on the car. Fit both 4 spd and auto no problems,too bad they are not still around.
I also have a set but I'm curious what did it cost to get yours jet hot coated and where?
Reason: Added content
Got my blackjack alumnakote headers with anti reversionary cones in the mid 80s, and they are still going strong. I plan to have them jet-hot coated soon. These headers give the most undercar clearance, and they work fine with my angle plug AFRs.
