Stuck Wheel Help!!!
Old Mar 7, 2007 | 04:37 PM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Default Stuck Wheel Help!!!
No doubt this Vette has set for a loooooooooooong time. THe right rear wheel is frozen to the hub. Any suggestions to remove. I have tried wacking it with 2x4, hammer to 2x4, applied rust solvent. Oh yea, applying jack under tire and lifting car. Hows that for lock tite
Apply Heat? Cold?
Thanks in advance.
tt
Old Mar 7, 2007 | 04:48 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Thread the lugs on the studs just enough to keep the wheel from falling off and then lower the car to the ground. Rock/roll the vehicle as necessary to get the wheel to separate from the hub.
Old Mar 7, 2007 | 05:20 PM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Just got off phone with Fellow Vette Friend, he suggested dang near the same thing, put lugs part way on, and drive up drive way. (He lives life more dangerously than most of us). My luck, half way up drive, tire will come off, rip off fender, hit tree, bounce back into cab, hit me in head. Wife may like that...
Thanks for the help, keep ya posted with results.
tt
Old Mar 7, 2007 | 06:28 PM
saudivette's Avatar
saudivette
tt
Then bounce off your head into the neighbour's Merc or Beema...
Old Mar 7, 2007 | 07:49 PM
GDaina's Avatar
GDaina
you need a sledge...if you have steel wheels, a couple good whacks will do it...but whack a 2 x 4...have someone hold the board while you whack it...
good luck
Old Mar 7, 2007 | 09:46 PM
VettePower's Avatar
VettePower
good luck
Just don't miss and hit your leg!!
Old Mar 7, 2007 | 10:25 PM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Update:
Success! After continued rust buster, I heated the center, sprayed cold buster on the wheel, still no luck. Put all wheels back on car, rocked car violently, no luck.
Got really mad, broke out my sawzall, less cut the freeking tire off this &*^%^ then I'll take a wedge and beat it off. (The reason I am taking wheels off is for new tires, these are maybe 20 years old and dry rotted). Put the sawzall on tire, hit the trigger, cut about 1 minute, deeper into tire the violent action of the saw along with everything else it came loose. Dang, I feel like I have had my butt kicked on this one!
tt
To Stuck Wheel Help!!!
